Question about Maytag EPIC MFW9700S Front Load Washer
Washing machine balance is off since we moved it.
How do you balance a front load washing machine after moving it? It walks forward when spinning. Is there a way to balance it?
  • 10,319 Answers
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
Posted on May 12, 2010
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Washing Machines
The dial moves forward several numbers when set on a wash and it does not spin, it drains, makes a sound as if its going to spin but doesnt. The clothes are not washed properly nor spun when I eventually...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | Washing Machines
Washer walks when it spins
It is probably due to the unbalanced load in the machine and
when spinning,it will make this motion.Try to balance the load
better when washing.
Apr 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
During spin, machine moves!
Did you remove the transport rods from the back of the unit? this will cause the unit to jump around a lot when it goes into the spin cycle. Also make sure the feet are all level and the unit doesn't rock from side to side.
Mar 22, 2010 | LG WD-16115FD Front Load Washer
The machine is level but the drum spins as if it were not. loud and the machine moves forward
These new front load machines are much heavier and spin much faster than the top load machines. If you have old wood floors in your home or you live in a mobile home, the machine may tend to "walk" or vibrate on the floor. You can try putting something under the machine to help prevent it from walking as it is spinning.
Feb 23, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The washing machine is balanced, however it moves on the spin cycle. The actual machine moves forward and is very dangerous.
go to a place like walmart in the fabric section, they will have some stuff thats made to put under rugs to keep them from sliding, i call it rubber lace. cut some and put it under the feet.
Dec 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Moving
Don't know if you've done it, but put a level on the machine itself and make sure it is level. Adjust it front, back and side to side. This may cure your "walking problem".
Jan 28, 2008 | LG WM-2277HW Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
309 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
