Question about Element Electronics Televison & Video
The tv made a whooshing sound then smoke came out of the top picture is out but every thing else is fine
  • 10,515 Answers
I am Sorry to Hear regarding the Problem.You first would need to disassemble the screen to examine the mirror and lens. The mirror is probably the most important thing to keep clean, and you can clean it with any foaming glass cleaner or a 50/50 mixture of 92% pure isopropyl alcohol (from any drugstore) and distilled water. Use a clean terry cloth towel.
But if that doesn't correct it, you may have to call a tech. You may have a problem with the light engine, and it may not have had anything to do with smoking. Unfortunately, many rear projection digital TV's are developing problems with light engines, and not just Hitachi, and that's why I urge anyone who buys a current technology HDTV to get an extended warranty. All of these TV's, regardless of whether it's plasma, LCD, or rear projection, have large and expensive assemblies that cannot be fixed, and must be replaced.
But definitely check the lens and mirror first.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
  • 2 more comments
  • lofc1096 May 12, 2010
    took off the middle part of tv it is a lcd and my daughters tv did the exact same thing . when you say check mirror does that mean i should take off the whole back of the tv? It looks like its on the left side by looking through the slats. am i right? and when you say a foaming cleaner can i use windex
  • taran_2005
    taran_2005 May 12, 2010
    Thanks for your response!!
    You never mention the Make and Model of the TV. But, if that's Mitsubishi,the procedure is :-
    Turn power off and unplug.
    Remove screws on rear at top and on both sides of the screen.
    Remove speaker grill.
    Remove screws on each side of the screen where screen meets the speaker area. Remove two screws in center area of speaker area under screen.
    Lift screen up and away from set housing.
    Clean the mirror.
    Yes, you could use Windex.
    Hope i helped you.
    Thanks
    It's by element about 3 to 4 years old
  • taran_2005
    I am glad that you mention this Brand. Do you have the Model Number? Is it 32"?
    Let me know,so that we could Proceed.
    Hope i helped you.
    Thanks
My gas pool heater was running, then it made a whoosh sound and went out. I restarted it and it fired ok, but there is smoke coming from the exhaust.
If its steam or white color you may have a leak in the heat ex changer dripping water on the burner. The "whoosh" sound may have been when the leak started and put the burner out.
Jul 16, 2017 | Pool & Spa
Tv went crack while watching. Picture and sound went out & red light flashing.Waited a min,turned off and back ok with picture and sound returning concerned if we should continue using or not?
As long as you can see and here the picture with no problems you should be fine. The tv's put it heat which make things expand and contract. Sometimes things creek and crack. I've had two tv's that do that. Don't hesitate to keep a fire extinguisher handy though along with some alarms.(houses should have these at all times anyways)
Mar 07, 2015 | Televison & Video
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Toshiba 50A61 have sound but no picture - all fuses check okay
Not too many--if sound is developed from the set and not a surround system the set will blank the 3 picture tubes for a few reasons:
Voltages missing at the tubes (high voltage or screen voltages etc)
There is a loss of vertical sweep or horizontal sweep--set will do here this to prevent an INSTANT burn mark on all 3 tubes.
One thing you can try to look for is to see if the filament in each tube is lit---rather dim as 6.3 volt one---if lit the above reasons are your problem.
Without a meter, a schematic etc not much more you can check.
You should hear a faint whoosh sound when you power the set on--the high voltage coming up.
Jun 07, 2012 | Toshiba 50A61 50" Rear Projection...
No soud just a 'whooshing' noise...
Make sure that you have second audio program turn off.
Nov 23, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Whooshing sound coming from front tire
Sounds like a few things. Flat spot on the tire. Something caught in the tread. Jack up the vehicle and turn the wheel by hand and see if you can recreate the sound, if you can you will find the problem.
May 16, 2009 | 2003 GMC Envoy
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Televison & Video Logo
27 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
