Question about Quantum Audio QCA2000D Car Amp
I have a Quantum audio Solar Series Amp and the red light comes on how do i fix it?
Lightmates power series model 348695 sensor blink red no light
Had same problem on my unit and temporarily removing the battery and charging it for 24 hours with a modified 7.5 volt 200 ma. power adaptor seems to resolve the issue. Lamp is now working, hope this fix will last. Seems the solar panel does not charge the battery fully. Tried locating a replacement battery to no avail. The battery is 8V3.5AH, no other model information. Battery is 3.75" H x 3.5" W x 1.75" D
Mar 15, 2013 | Televison & Video
Need bass nobb for my amp
need a remote and quote fora bass knob remote Alpha series quantum amplifier QA3000D Mono Amp.
Nov 09, 2012 | Quantum Alpha Series Qa3000d 3000w 1 Ohm...
Quantum audio qca4000d mono block amp 4000 watts cosmic series. when car is turned off amp works fine. when I start the car protection light kicks on. Whats wrong
How do u connect a quantiam audeo 4000 monoblock wats with 15s q powers I tryed it but they do not sound da way I though they were going to sound let me no som thing thanks?
Nov 09, 2011 | Quantum Car Audio & Video
Subs just rumble at higher levels...??? help!
there is a loose piece inside my 10" cozmik series. how do i get it out?
Mar 12, 2010 | Quantum Audio Cozmik QCA2300 Car Amp
Amp will not put out sound The red light comes on
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Dec 28, 2009 | Solid Audio Formula Series F2000 2-Channel...
Switched amp to anther car red protector light stays on i have a quantum audio 2400 amp
unplug input raca's one at a time. turn off, then on. repeat until all you have is the 12Volt wire, the remote wire and the ground wire connected. if you get it to work after you unplug one of the rca's then you have a short. if not then remove all speakers connected, again one at a time until you don't have anything connected. this way you can find out which component is shorted. if you unplugged all rca's and speaker out wires and unit still stays on protect mode, check fuses. if ok, then your amp may have shorted out.
Sep 15, 2009 | Quantum QA2260 Car Amp
Quantum Audio QCA2000D Car Amp Logo
73 people viewed this question
Top Quantum Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Quantum Audio Car Audio and Video Expert? Answer questions, earn points and help others
