Question about 4Button Remote Transmitter For CS2000DPII And CS865RKE
Need a manual for a Crimestopper RS-1304DP Remote Start System
I have a 4 button remote with two buttons on the side. It says cool start on the front. I bought the vehicle with this remote and do not know anything about how to program it. Can I get a .pdf of the manual? I believe that the system is a Crimestopper RS-1304DP system???
Brett
3 Suggested Answers
  • 20 Answers
SOURCE: Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
Posted on Feb 09, 2010
SOURCE: COOL START REMOTE NEEDS REPROGRAMMING
so this morning i tried to remote start my truck the truck turned on and it stayed on for 5 sec turned off again 3 sec later it turned on again for 5 sec and turned off agin doin the same problem over and over any ideas what this problem can be>? its the cool start idk which model # i bought the truck with it
Posted on Nov 18, 2011
How to program a crimestopper remote control model #chx433tx
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
Mar 07, 2011 | 4-Button Remote Start/Keyless Entry with...
I have lost my 4 button coolstart car remote ser rs-830/rs-810 need to order a new one
You can purchase the remotes directly from Crimestopper or call them to direct you to a dealer near you. Their contact and order information can be found at this link:
Crimestopper contact page
The following 2 links will help you identify which remote you need.
Remote chart by system number
Remote identification by image
Nov 08, 2010 | 4-Button Remote Start/Keyless Entry with...
I have a Crimestopper rs-3. I have had 2 instances where my car won't start with the remote or the key. This was just installed 2 weeks ago. Had a tow truck come to tow it to a local garage. The driver...
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
Oct 29, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
Oct 17, 2009 | 2-Way Remote Starter
Remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Jan 06, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Dec 16, 2008 | 2-Way Remote Starter
Ezee start remote stopped working
if you have the manuals look under transmitter programming. if not go to crimestopper.com and look under manuals and you can download one from there and follow the steps into reprogramming the transmitter.
Nov 26, 2008 | Crimestopper EZ-95FM EzeeStart 2-Way FM/FM...
4Button Remote Transmitter For CS2000DPII And CS865RKE Logo
382 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
