Question about Samsung NV3 Digital Camera
Having the same problem as you...
I have just got a Sumsung NV3 digital camera. Instead of the regular USB cable I am used to, I also just have the white and yello cables. I think I have found where to put the yello, but not the white. Did you find a way of uploading your pictures? Please help if you can. Thank you..Faye,
  • Anonymous May 20, 2008
    how to upload photos from samsung NV3 to the computer..
Am I just stupid? Thank you, I would never of found it there...
Posted on Apr 06, 2008
Pull the cable from the plug adn you will have the usb connection
How do i connect my samsungnv3 to a pc
Connect the camera's USB cable to the camera and then plug the other end of the USB cable into the computer's USB port. The computer will see the camera as an external storage device, open this device and folders to copy the photos to your computer.
Aug 12, 2012 | Samsung NV3 Digital Camera
My samsung nv3 digital camera wont turn on and when i connect to computer via usb nothing happens. it just seems dead
Do you have the CD installation of your camera? When bying the camera, you may have a CD with. So you have to use this CD to install your camera if windows doent make it automacaly
Feb 04, 2011 | Samsung NV3 Digital Camera
Sdhc card used in samsung nv3 it says memory full
I don't think that camera (the Samsung NV3) takes SDHC cards. The same is true of many (perhaps most) cameras that were released more than a year or two ago.
You need to use a regular SD card, which -- as you probably know -- isn't any bigger than 2G.
May 20, 2010 | Samsung NV3 Digital Camera
I have a Samsung NV3 camera. It records videos,
You need to download codec which should be updated regularly
Aug 21, 2009 | Samsung NV3 Digital Camera
Does anyone know how to hook up a sumsung nv3, which comes with a yellow and white cord, one that hooks up to the TV) or is there another cord that was lost. I don't know, but if you can help I'd...
Thank you for using Fixya. Does the yellow and white cord have a round end with a metal tip on the middle? If it does that is the RCA cable, and it is meant for the Audio and Video inputs of the TV. If it is not round, please let us know the exact model of the camera so that we will be able to find out how the cables should be connected.
With regard to the camera being connected to your computer,, generally what camera uses is a USB cable.
Jan 04, 2009 | Cameras
Memory card Samsung Nv3
This is a common problem and I had the same issue. Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work but I would try to find someone that has used the brand and size and knows that it will work.
Sep 08, 2008 | Samsung NV3 Digital Camera
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
Samsung NV3 manual really cheap ?
if you still have the original disk put it in and u should see and option saying manual it has the entire manual on PDF format
,i dont no about the usb mine automatically charges the NV3 from the USB i got with the camera
Oct 01, 2007 | Samsung NV3 Digital Camera
Screen displays 'memory full' with only 11 images
Here's a link to Samsung Customer Support for cameras: http://www.samsungcamerausa.com/support_contact.asp You should be able to get all your questions answered here. Good luck
Jun 13, 2007 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
65 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
