Question about Maytag Atlantis MDG7400AW Gas Dryer
Not heating redid laundry room, r&r dryer. starts, runs, not heating up. Gas is on, you can hear the gas going in!
  • godino7 May 13, 2010
    Problem solved!!!!!!!!!!!
    Thank you so much for the help!
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryernot heating - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troublnot heating - 2_bing.gifimg src="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 12, 2010
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Dryers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
The flame in my Amana dryer (LGB109 W2) lights but keeps going out? Is it the solenoid? Termastat? At first it wouldn't ignite. Now it always ignites but doesn't stay on.
hi,
if your laundry room has a door try leaving the door to your laundry room open, that may do it, gas dryers and appliances must be able to breathe..
Nov 28, 2009 | Amana Dryers
Longer cord/age of washer & dryer
Is your dryer electric with the big plug.
If so, what kind of changes are you making?
The dryer needs to be by the vent outlet so you can't move it far unless you are going to cut a new venting outlet.
If it is electric (not gas) then do not try to extend the cord. Have a licensed electrician move the electrical jack.
The cord has a large amount of current running through it and the longer the cord, the more resistance the current has to flow through. More resistance means more heating of the cord and less voltage for your dryer. This can result in the cord overheating to the point of melting and starting a fire itself or getting hot enough to ignite the very fine and very dry lint particles that are present in any laundry room.
This is a situation where you spend the money and have it done professionally because of the danger of fire, death, etc.
Good Luck!
Oct 09, 2009 | Dryers
Dryer does not dry
hi,
need to know if its gas or electric, easy way to tell is to look at the power cord going into the dryer, does it plug in next to the washer or does it have a thicker heavier plug near the floor? thicker plug means its electric, smaller cord means gas. Dryers are dangerous appliances. If you have any doubt what yoru doing stop and write here or call a pro. Be careful to shut the breaker off in the fuse box or shut the gas off outside the house before you do anything else. Most likely if its electric the element burnt and you need a new assembly, or if its gas has their been a disruption of gas service lately? How ******* is your laundry room? You should always leave the door open to your laundry room so the dryer can breathe. If you come to find that your laundry room may not have enough airflow, the thermocouple in a gas dryer will go if it cant breathe also. let us know
hope that helps
Jul 10, 2008 | Whirlpool Dryers
Whirlpool Gas Dryer
you will need to let it cycle a few times in order to bleed the air out of the gas line to the valve it should start up after a few attempts let me know
Jun 09, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
180 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
