Question about Dryers
My whirlpool dryer tumbles and runs but has no heat. Its a gas dryer and tge model number is LGR3624EQ1
  • csling76 May 12, 2010
    I changed the ignitor today and there still isnt any heat. Any other suggestions?
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerMy whirlpool dryer tumbles and runs but has no - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If youMy whirlpool dryer tumbles and runs but has no - 2_bing.gif"http://www.fixya.com/support/t4726170-load_takes_more_one_cycle_dry#">dryer is electric2_bing.gif..
There could be a number of different problemsMy whirlpool dryer tumbles and runs but has no - 2_bing.gifheck out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 12, 2010
Dryer tumbles and runs. Does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Whirlpool GEQ8858J Dryer
Whirlpool gas dryer model #LGR3624EQ1. Our dryer is not producing heat. Gas line is working and the vent is clear. It has airflow through the lint trap. It also continues to run and won't shut off. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Dryers
Tumbles, doesn't heat. Gas is on within house. Dryer is not blowing warm air.
Hi, If you have a gas dryer2_bing.gif.
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 04, 2010 | Whirlpool LGR3624JQ Gas Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If your dryer2_bing.gif is electric..
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Apr 08, 2010 | Whirlpool WED6200S Electric Dryer
White knight tumble dryer not drying clothes. element is still hot. what is the problem?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Mar 23, 2010 | Whirlpool Dryers
I have a Whirlpool Dryer Model number GEX9868JQ0 and it will run however; it is not blowing hot air? How do we remove the kickplate (front or back) to check out what is wrong? Please advise.
A typical problem that causes tumble dryers to stop heating up is the thermal overload cut-out devices. These are safety devices, and are some times "single-shot". That is, if they operate, and shut off the heating element, then they need to be replaced, usually as a pair along with the thermostat (they look very similar). The other common fault is that the heating element fails. However, if the thermal cut-out was the problem, LOOK FOR A CAUSE. If it is a condenser drier, check the condenser box is not clogged with lint/fluff
Oct 30, 2009 | Whirlpool GGQ8831L Gas Dryer
Gas dryer will not stay warm for long
Hi, You will need to replace the coils on top of the gas valve.
There is a small plastic cap that you can remove in the lower front panel. Start the dryer and see if the ignitor glows and shuts off before the gas ignites. If this is the case, the coils need replaced. This is a very common issue with the gas dryer.
Here is how to change the coils:
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
Top Dryers Experts
