Question about Vulcan AUW230A Heater
Is vulcan duct heater still in existence? My problem is the thermostat control for the room temp has gone out of control - from 22 -35 0C. This has affected the heater cut off efficiency.
    Sergeant:
  • 235 Answers
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
Posted on May 12, 2010
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
Vulcan Ducted Heater has gone into reset a couple of times in the past fortnight. This morning not in reset not functioning. Tried reset. no go, held reset on Bonaire wireless remote code F1 11 displayed??
Hello
You are experiencing a thermostat problem,what you simply need to do is to call up an experienced repairman and have the thermostat of your heater replaced
Apr 22, 2011 | Heating & Cooling
Position of ceiling diffusers for a ducted warm air heating syste
You want the air to distribute through the room as evenly as possible. You don't want the air to blow down in one spot. In a room where a thermostat is located make sure the air doesn't blow toward the thermostat or this will make the unit turn off before the desired temp is reached.
Nov 15, 2009 | Desa International CBN30T Central Heating...
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Cold Ait from heater ducts
u might want to check the blending doors that control ur ac and heater flow they tend to get stuck sometimes
Oct 25, 2008 | 2000 Ford Taurus
I have vulcan ducted heated model no. 9255. The comfort control is reading the room temp as 35C when it is actually 11C, yes its freezing here. As the room temp is at its maximum reading the heating is not...
I replaced the batteries, even though 'battery low' message was not displayed. this fixed my problem. I wish I'd have just done that to start with.
Aug 12, 2008 | Heating & Cooling
Vulcan cx90 ducted heater
240 volt wiring required.
Mar 06, 2008 | Heating & Cooling
Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Feb 24, 2008 | Heating & Cooling
Vulcan AUW230A Heater Logo
616 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
