Question about Kitchen Ranges
Hi,My Maytag performa stove model PER5710BAW clean cycle will come on for a short time and shuts off.What is the problem?Please help.Tks
  • banepilipovi May 12, 2010
    Tks your advise.I
    was thinking about the same solution that pcb board is the cause because after inintial start up cleaning cycle after a while shuts off and some niose comming from pc board.Pls advise .Problem is only that whole pc board cost 'only' about 165.00 us doll.Tks much
    Tks much .I wl try to open stove and make checks as per your recommendations.
    Tks again
  • 10,515 Answers
Could you please Tell me More, Do you see any Error Message? Any other Symptom that you might have Observed?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
  • 1 more comment
  • taran_2005
    taran_2005 May 12, 2010
    Thanks for your response!!
    I am sorry, i did not see any Comment, Posted by you after i asked for any Error Code?
    Hope i helped you.
    Thanks
    Tks much.No any error code ever.Only shuts off after approx 30-40 seconds.Tks much
  • taran_2005
    As there is No Error Message, it could be Hard in Diagnosing the Exact Reason without looking at the Machine. Make sure that there is No Loose Connection or Wires. I would suspect Control Board as nothing could stop the Power other than this to Bake and Broil in this Model.
    If you have a meter you can make sure that the broil and the bake are both getting 240V at the elements but I'm fairly certain that will come up negative as 2 elements never burn out at the same time.
    Let me know,if needed further assistance.
    Hope i helped you.
  • 6,784 Answers
HI. There are only two reasons for this type of interruption during the cleaning cycle. The first will be a fault that may exist within the main PCB. There is a relay that controls the door locking mechanism(located and mounted on the main PCB). If this control relay fails, or it is slightly defective, it will not allow for a proper cleaning cycle, due to the controls failure to send the locking command or hold the current properly. In order to inspect the relay and control board you will need to gain access to the main PCB, usually mounted on a bracket in the control panel section of your unit. Once the main pcb has been removed from the control panel, kindly, inspect for visual burn marks at the relays mounted on the back side of the board. I should point out that the relay may not show visual signs of damage, but your symptoms are a very strong indication of this type of damage in this area of the board.
Now, the next area of concern will be the actual door lock mechanism or switch. This switch is the actual mechanism that receives the energized signal from the main PCB to activate the locking of the door latch. This circuit may be faulty. i would recommend to check the connecting wiring harness for corroded contacts and proper connections to and from the main PCB. Once you have verified that the wiring is ok, move on to the testing procedure for this switch.
Door locking mechanism switch continuity test procedure:
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. OK, once you have gained access to the locking mechanism, set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
In conclusion, if the door locking mechanism switch circuit shows good continuity, simply replace the main PCB.
  • 1 more comment
  • Michael Masters
    Michael Masters May 12, 2010
    Ok, if the noise is definitely coming from the PCB, it will be located at the relays located on the backside of the board. the only solution will be to replace the PCB. The individual relays are not available for purchase. only the entire board can be purchased. if you have the funds available,i would recommend to purchase the PCB.
    Now, if this is not cost affective solution, I would then advise to simply purchase a new unit.
  • Michael Masters
    It shows that you have given me a poor rating of two thumbs and have chosen to move on to the next expert. I am not sure what i have said wrong, but i do respect your decision.
    Good luck:)
  • Michael Masters
    OK, I will be standing by for further discussion on this issue..
The front right element on the stove top comes on full heat when the control is set to three or four. It doesnt cycle. just wide open throttle. My wife says if She turns it off and back on it starts...
The "infinite switch" is sticking due to burnt contacts. The problem will only get
worse until it is replaced. You will need the model and serial number, generally
located behind the lower drawer to get a replacement. (usually around 40 dollars)
Unplug unit or shut off stove breaker and remove (usually 4 screws) for the control panel. You can make drawing of the wires or use a cellphone to take several pictures
before replacing switch. (do not try changing switches around as they are different
amperages). Also check the burner socket itself, it may require replacement as
well. (They can short out on the chassis and ruin the switch). Hope this is helpful.
May 30, 2011 | Maytag PER5710 Performa Electric Kitchen...
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Oven won't work. Maytag Performa Stove. Broiler and burners work.
sounds like your bake element is gone
but the model number would help a great deal
pul out the stove unplug it, take off the back, and inspect the connections on the bottom element
if its gas its probably your ignitor
take out the racks
take out the bottom
set to bake
you should see a very bright light within a minute
if you dont thats the ignitor
anyway both parts are available
and both are a pretty starigt forward repair
Oct 09, 2009 | Maytag Performa PAV2200
Where can i find a replace glass top for a maytag performa stove
Hi, get ma a model # and I can get you part # and location of a glass.
Vic
Jun 06, 2009 | Cooktops
BURNER ON STOVE TOP NOT WORKING
some dirt or spilled food is in the orfus tbue or holes forcing it to come out under the burner!
If you ever replace the unit, get sealed burners the you can take them off and clean them!
GET HELP.
THESE GUYS CAN HELP!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Performa by maytag 8kg toploader
Click on 'washing machines' (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. Go to Maytag, look for toploaders, 8kg. Best of luck, if it's available, you're saved...........
Feb 10, 2008 | Washing Machines
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
