Musty smell coming from machine - Washing Machines
  • 10,319 Answers
Small hidden water leaks will cause a musty smell. Usually the leak is from a dried out hose
Posted on May 12, 2010
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi I have just moved into a new house and there is a musty smell coming from the electric Dimplex heaters fixed to the walls. is there any way of getting rid of this smell? thanks# Mary
Are the heaters hydronic? (Heated water flowing thru tubes) If so, the musty smell is because the water has been leaking which is obviously a problem. I know you mentioned that they are electric heaters, but "musty smell" goes hand in hand with moisture.
Aug 03, 2011 | Heating & Cooling
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
My clothes are coming out smeeling musty
I have a zwf1241w with similar problem. When I disconnected the drain hose that runs from the drum casing to the pump housing there was a lot of collected debris that had prevented the water from draining through properly. You could try clearing this out.
Oct 06, 2009 | Zanussi F1045W Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
