Question about Samsung SGH-D500 Cellular Phone
Vibration pattern wat menu option do i go into to change the vibrating pattern?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 131 Answers
Click Here to Email SUpport for a step by step instructions.
Posted on May 12, 2010
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
My vibration has stopped working on my 8800 arte? wat is the prob
That is a great phone.
The nokia menu system is confusing - when you change from 'silent' to 'normal' to 'outdoor' or any other setting, the entire ring profile changes.
I think what you have done is switch profile to a setting where the vibrate is not set to on.
simply go into the menu, select vibrate, and turn setting ON.
be aware that if you change from this setting, it may go OFF again.
Good luck,
Please vote for a positive rating for me.
Scott
Mar 03, 2011 | Nokia 8800 Arte Cellular Phone
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
Jan 16, 2011 | LG Cell Phones
Ringer rings continously without pausing when receiving an incoming call
My phone no longer does the rhythmic vibration for incoming calls. I used to have it set up to vibration type 2 (where it vibrates in a certain pattern). However, as of last night, any incoming call just vibrates regularly instead of in a pattern. I checked to make sure that the setting was not changed, and everything looked ok. Is there a registry edit I can do to change this? I would rather not hard reset my phone, but I will have to do that if there's no other way. Thanks
Aug 11, 2010 | Vtech CS6219 Cordless Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
Turn vibrate on ?
let me sole it by steps do it step wise
press
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 | Cell Phones
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
XBOX 360 CONTROLLER
I think it's known as vibration not vibrator, anyway... Depends on which game you are playing, there should be an option to turn off vibration from within the games menu, usually under 'options'
Nov 18, 2007 | Video Game Consoles & Games
Samsung SGH-D500 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
