The CD or radio play intermittantly when wiggling the power cord. When working, the Power/Batt indicator is on, with or without batteries. It appears the SPDT switch near the plug may be the problem but am not sure what to do about it. Can I remote this switch to fix the problem? Is it supposed to switch from AC power to battery power when the plug is removed? When the switch is made, it appears that the common lead becomes open to one pole and closed to the other. Is there a wiring diagram for this switch? Can you answer these questions please?
  • 2,427 Answers
Actually it may be a\even simipler than that..
  • open the raido
  • resolder the wires to the switch and power points..
if that fails replace the power wire..
try that your problem will be fixed :)
Posted on May 12, 2010
  • ltgompert May 12, 2010
    I didn't try resoldering the wires but they all looked good. Pressure on the plug, properly applied, makes it work, and will continue to work unless jiggled (with or without batteries). A new power cord works about the same - doesn't alleviate the problem. I tried closing the gap on the switch actuator, but it is stiff and difficult to adjust, making me think that if this is the problem, substituting a remote switch might fix the problem.
    It's likely the AC power contacts are bad, but this would be difficult to fix. The radio works well on battery only, with the plug removed. Can I order the receptacle only? I take it the leads are integral to the receptacle and are connected at the transformer?
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
I was recieving warnings upon booting to contact hp about a replacement battery. ignoring this my notebook stopped working. The power led's on the side of the note book indicate it is getting power,...
Did you try using another power cord to see if it starts? Could be a weak power cord or intermittent failing power cord.
Could also be a short in the system preventing power to flow through the laptop
Aug 27, 2011 | Computers & Internet
Radio plays with batteries but when power cord is used the display says check battery.
Connect the power cord to the radio without the batteries inside, i mean remove the batteries from the radio, and see what it will display.
May 29, 2011 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
2004 Toyota Corolla Verso has intermittant sound and control problems. The radio will play fine and suddenly the sound will go off as well as the back lights illuminating the radio face and knobs.trying to...
The problem sounds like intermittent power supply. There might be an inline fuse which sometimes does cause problems. Remove the radio and check the power line to see if there is such a fuse. If so, remove and clean it with a bit of sandpaper, put it all together and see if it helps.
Sorry, can't be more helpful.
Aug 29, 2017 | 2004 Toyota Corolla
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
Try removing batt and use ac adapter alone. Check if laptop works fine also check if LED flickers still.
Try removing ac adapter and use battery alone and check if batt flickers as well.
If flickering only happens when both are connected or vice versa try this first. Update the BIOS for your laptop. Download the BIOS update from http;//support.dell.com
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Radio works on ac power but not on batt power
"Radio works on ac power but not on batt power AA batt seams to be ok" The AA battery is only for the radio memory and clock. Have you put a battery from your drill in the radio? if so check fuse inside radio.
Sep 13, 2009 | Dewalt DC011 AM/FM Radio
Citroen Saxo CD Player will not play when engine running
The car stereo has 2 +12V inputs: the constant batt input and the key in one.
So actually the stereo is always connected to +12V, even in standby.
When you turn your key, the key in input also starts, thus starting your stereo instantly.
When you turn the ignition on, the key in input is switched off for a couple of seconds, so that all the power goes to starting your engine.
After that key in input should be back on - this is your problem here.
One possible solution would be to cut this wire out, and split the RED battery +12V cable so that it enters in the key in input as well. Check wiring diagrams!.
Test this with cables out (without reinstalling the whole thing back in) and if it works.......leave it and put everything back in.
Only downside is, you have to turn off the radio by hand when you exit your car - or you could lose all battery power !
Jan 16, 2009 | Car Audio & Video
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
23 people viewed this question
 Grubhead
Grubhead
