TV comes on with black srcreen,and Blk screen has a 2in wide grey line comeing down center screen turning a jagged red feather like in shape.
  • Yanick Martin
    Yanick Martin May 15, 2010
    i am looking for a second opinion on a Panasonic fix,26 in lcd tv, with line down middle.I will provide photos and other info to make it all easier for both of us.
  • Yanick Martin
    Guru:
  • 416 Answers
Sounds like your TCON (Timing Control) board on the LCD panel has failed. This part is sometimes available separate from the LCD panel, but sometimes not. If you provide the make, model (or Service model) and any version number (if it has one), I may be able to provide a part number to you.
Posted on May 15, 2010
  • 3 more comments
  • Adam Halfhill
    Adam Halfhill May 15, 2010
    Panasonic... sorry, I think you will need the entire LCD panel for this repair. I don't know of any Panasonic LCD TVs that have separate TCON boards available. If you could, a picture would do nicely... always a good idea to see what the defect looks like.
  • Yanick Martin
    Give me a email and I will send pics of the screen, and inside boards,The owner also said the line you see in pic was there from the day he purchased it, but very faintly and got worse as tV aged. ,,,After I told him it might very well be the LCD screen,Why he with held that info I dont know,,
  • Yanick Martin
    Yanick Martin May 16, 2010
    TC-26LX20 is panasonic model number on it...
  • Adam Halfhill
    Adam Halfhill May 16, 2010
    email: milkburp@cvzoom.net Also, I looked up the LCD panel for that TV. Cost is almost $1,900.00, not the most economical part for replacement. After you send the photos, I'll get back to you with my opinion.
  • Yanick Martin
    Yanick Martin May 17, 2010
    Sorry it took so long I had running to do today, they are on the way.
    President:
  • 1,768 Answers
1. Your TV needs service. It has a power supply issue and a vertical sync issue. This will need a schematic and a tech with a scope to pinpoint the defective components in said circuits.
  • 566 Answers
Hi thunderz
I`m going to help you with your tv but first;
Can you give me the brand name and model number?
Posted on May 12, 2010
  • 35 more comments
  • Yanick Martin
    Yanick Martin May 12, 2010
    panasonic LCD flat TC-26lx20 model
  • Jacques Marin
    Jacques Marin May 12, 2010
    O.k
    I`d have another question;
    Do you have normal sound?
  • Yanick Martin
    Dont know if its normal because I dont have it hooked to cable right now,but it has the sound as if its not on a channel like a snowy pic would.And the snowy pic came on more than black when I tured the sound up,but still has the line down middle of screen.
  • Yanick Martin
    okay I turned it up all the way and it got louder ,Iguess you could say thats normal.
  • Jacques Marin
    Can you get the sound if you hook up the cable?
    And does it affect the picture?
  • Jacques Marin
    Also do you get the menu?
  • Yanick Martin
    I do not have the remote as I took this for repair and forgot to get the remote,,,But,When I manually swith channels the numers lite up on screen and switch from vidio to tv The word JUST and DVD lite up on scree, so I think the menue would come up if I had the remote. I looked and there is no manual way or button to bring up menu
  • Jacques Marin
    O.k but you did`nt say i you had some way of connecting either the cable tv or dvd to see what kind of picture you may have.
    Also if the screen gets affected by the sound level then i would tend to go for a faulty power supply board.
  • Yanick Martin
    Okay I hooked up cable and than a rabbit ears after for local channels and all it did is get a salt n peper snowy and the line down the middle still there.
  • Jacques Marin
    Well the snowy picture could be bad reception with the rabbit ears.
    But what about the sound : does it still affects the picture?
  • Yanick Martin
    No the sound only did that before because I hit vidio by accident and the screen was black with the line and when I switched it back it was snowy and when I put cable ,and than local antena it brightened up both times and volume was ajustable either way.
  • Jacques Marin
    O.k then;
    What you have is either a bad lcd controller(t-con) or the lcd panel itself is faulty.
  • Yanick Martin
    Okay is there a way I can be sure of either? Like a test of some kind?
  • Jacques Marin
    The only test is to replace the lcd controller board , also called t-con.
    That board is located in the upper center at the back of the lcd panel and it has a metal shield covering it.
  • Jacques Marin
    I`d say that 75% of the time it will be the problem.
  • Yanick Martin
    Do you the cost of the board and a good site to purchase one?
  • Jacques Marin
    The cost usually goes around 70 to 80$.
    I can take a look to see what i can find ,but you may have to take it off to give me the numbers written on it.
  • Jacques Marin
    O.k i found something here;
    http://www.discount-merchant.com/PANASON...
    In your tv they call it the logic board.
    But you`ll still have to look at the one you have now to make sure it has the same part number.
  • Yanick Martin
    Well I got the back off and everyboard in there has a TNP start to every board number.Can I send ya a pic of the inside of this tv and help locate the right board,,,As it looks none of them match the one on the site.
  • Jacques Marin
    o.k you can send me the picture(s) at ;
    marinjacques@hotmail.com
    Try to get a general view then the different sections.
  • Yanick Martin
    The pics are on the way, I also gave the number on the center board. Let me know if you need more.
  • Jacques Marin
    I got the pictures.
    I`m gonna have to study them and do some research on it.
    Could i get back to you tomorrow evening and what would be a good time?
    My time here is 11:20 EST
  • Jacques Marin
    I actually should be back online at 4:00 pm EST
  • Yanick Martin
    Same time here, you must be in canada? French name! Im in Erie pa. not far from Niagra falls.
  • Yanick Martin
    okay I will be looking for you around that time ,Im on here all day and most of nite,See ya then
  • Jacques Marin
    O.k sonny
    Talk to you then
  • Yanick Martin
    Okay Im here , Did ya find anything else out about the board?
  • Jacques Marin
    Hi again sonny
    Was looking at your pictures and ;
    I can`t see the board that we were talking about,
    so that means that it hidden underneath the frame that hold those boards.
    But in any case it might be irrelevant at this point because: after looking at those pictures i believe now that your lcd panel is the problem.
    What i can do is take those pictures and ask a friend of mine who is an ASC for panasonic and ask his opinion on this.
  • Yanick Martin
    Okay,LCD panel do you mean the actual screen? And what do you see that leads you to that problem?If you need any close up pics of any area I can send the.
  • Jacques Marin
    Yes that would be the screen itself.
    The reason i`m saying this is because the splatter coming down is not straight or linear like it usually is with a t-con or logic board problem.
    But then again there is a first for everything , so i`d like a second opinion on this.
  • Yanick Martin
    Okay how long should it take to hear back form your friend? ah should we make another time to meet back on here? and if you find anything sooner just email me and we can get back here.
  • Jacques Marin
    It should`nt take too long.
    Tomorrow or friday at the most.
    So i`d rather make sure before i tell you to replace parts.
    Either way you`ll receive an email when i have more info.
    By the way: yes i`m in canada, just across the river from ottawa.
  • Yanick Martin
    Okay sounds good to me,I have cousins in Hamilton not to far from me.I will wait to hear from you.
    thanks for your help so far!
  • Jacques Marin
    O.k talk to you soon.
  • Jacques Marin
    Jacques Marin May 14, 2010
    Hi again sonny
    As i said i took those pictures to a friend who is an ASC for panasonic and he thinks also that the problem is with the display panel itself.
    Apparently panasonic has issued service bulletins with similar pictures about bad lcd panels.
  • Yanick Martin
    Yanick Martin May 14, 2010
    okay what can be done with the lcd panel? can it be replace?
  • Jacques Marin
    Yes it can be replaced but it may prove to be too expensive for a 26" tv
    Your talking about 250$ for the panel and most of the time the tv`s eeprom will need to be reconfigured in the service menu/mode.
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Wiring diagram pioneer dxt-2369ub
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Nov 30, 2011 | Car Audio & Video
When I turn on my tv all that comes on is three 6"blue lines no picture is my tv toast
Hi:
If these lines are at least 2 inches wide then the problem is the display driver boards or some call them the Buffers boards, if the lines are less then 2in in wide and are very thin lines then the PDP is bad (Screen).
Nov 08, 2009 | Akai PDP4206EM Television
I have a red line in the same notebook, dell insp 1501
It's a faulty screen.
Here is how to remove old screen.
Then order new screen by DELL PART NUMBER (green), which is on the back of the screen and looks something like that:
If you will replace screen with any other (not with dell part number), then you risking, that screen will be dark and adjustment of brightness will not work.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Screen Problems with HP laptop
i think it is under of waranty. it look likes your graphic card or emmeded chip is down. need to get service.
May 27, 2009 | HP Pavilion dv6000z Notebook
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
I cant figure out the rear speaker color codes on my 1996 pioneer deh-p725 car cd player, could someone help me?
red---------ignition
orange----constant
black------ground
blue--------remote
green------drvrs front
grn/black--drivrs front neg
grn/red------drivers rear pos
blk/grn-------drivers rear neg
grey pass front pos
grey/blk---pass front neg
grey/red---pass rear pos
blk/grey---pass rear neg
Gary
Jan 25, 2009 | Car Audio & Video
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
