Question about Toro Garden
How to drain oil on a toro 20040 SR-2105 GTS 6.5 HP Super Recycler
4 Suggested Answers
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
SOURCE: I have a Toro Super Recycler GTS 6.5 HP. Upon
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Posted on Jul 22, 2010
hunter19_46m
  • 7482 Answers
SOURCE: toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Posted on Aug 18, 2011
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
Aug 18, 2011 | Toro Power Lawn Mower
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
or
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
Fuel
Look for an oil dipstick on the mower's deck. If there is no dipstick, it takes mixed gas.
May 25, 2009 | Car Audio & Video
May 19, 2009 | Garden
How change oil on my Toro GTS 6.o HP lawnmower
the drain plug should be under the blade plate, remove the plate to expose the drain plug, should have a quarter inch square drive or a half inch square drive, undo it to drain the oil.
Should take around .5 of a litre
Apr 11, 2009 | Garden
Garden Logo
277 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
