Question about Hampton Bay AC418-OBB 60'' Brookedale Oil Brushed Bronze Ceiling Fan
My Hampton Bay Brookedale ceiling fan has three speeds but will only work on one speed no matter if I push low, med, high they are all the same.
    Problem Solver:
  • 6 Answers
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
Posted on Jul 20, 2010
    President:
  • 1,871 Answers
Hello :
Try this solution .
good luck .
Posted on May 12, 2010
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
Fan doesn't work after nearby lightning strike
Your issue is most likely a faulty speed control, which presumably was destroyed by a power surge. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
Unfortunately the Brookdale fans with a Rhine 7058 series controller have a separate circuit wire for each speed. Rewiring this to use a conventional fan receiver that uses a single wire to control each speed is not easily achieved. Your best bet is to order a new remote receiver of the proper type.
Jun 04, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Installation:
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
Altura 68" fans will not operate on high speed.
I jtoo, ust bought The Altura (68" fan from home depot)
Home depot makes hampton bay through various chinese manufacturers.................
The fan ran slow on high speed, and barely ran on medium or low.
home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
They are sending the capacitors in 3 days to me no charge.
They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
My guess is they are under rated for a fan that big and are sending better ones to those with problems.
Hope this helps.
The number is:
1-800-330-3267
Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Feb 25, 2008 | Dryers
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay AC418-OBB 60'' Brookedale Oil Brushed Bronze Ceiling Fan Logo
675 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
