Question about Brother MFC-8220 Fax
Every time I turn on my computer and/or Brother mfc-8220 the led displays "pc busy or fail" message. At the same time it beeps 8 times. it does this twice and then remains quiet until I send a print job to the printer and then it goes through this again. I am using windows 7 with this printer. I have uninstalled and reinstalled the software and drivers twice. Any help?
  • paclow May 13, 2010
    1. I installed the correct and up to date drivers.
    2. I tried three different USB cables with no success.
    3. I purchased a parallel to USB cable just to try and interestingly it is now working fine? For some reason my computer and the printer do not communicate well using the USB cable.
    I am not sure what is going on but it sall seems to work fine now....
  • 240 Answers
First of all you want to make sure you are using the most up to date drivers.
Please make sure you are using these drivers http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/004300/dlf004335.html?reg=us&c=ca&lang=en&prod=mfc8220_us&type2=1&os=92&flang=8&dlid=dlf004335
If this does not help, please try using a different USB cable.
Also make sure you are not using a parallel cable or a parallel to USB converter and you want to make sure you are not conencted to a USB hub.
Thanks,
Pat
Posted on May 12, 2010
  • Patrick Wolthausen
    Patrick Wolthausen May 14, 2010
    It's possible that there is a problem with the universal serial bus controllers, when you connect directly with a USB cable there is more of a current going through the cable. With a parallel to USB cable there is no current and so the conflict does not happen.
    Happy to see the it's now working for you.
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
How to set the date and the time in brother fax mfc-8220? what's the steps?
Your MFC displays the date and time and if you set up the Station ID
it prints on every fax you send. If there is a power failure, you may
have to reset the date and time. All other settings will not be affected.
1 Press Menu, 0, 2.
2 Enter the last two digits of the year.
Press Set.
3 Enter two digits for the month.
Press Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day.
Press Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the MFC is in
Standby mode.
thx, if this helps please rate :)
Jan 27, 2011 | Brother MFC-8220 Fax
The LCD screen keep displaying "Printing" but
I have seen this so many times I thought I would post an answer on this so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
Good Luck and Thank You for using Fixya!
WheatlandServices
Dec 16, 2010 | Brother MFC-8220 Fax
LED READS Gibberish on Brother MFC 8220
Try changing your local language on the maching to English. ;-)
Mar 21, 2010 | Brother MFC 8220 All-In-One Laser Printer
Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Feb 28, 2009 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC-490cw stopped working
I would think so! Here's how to contact them. They will need your model# and serial# of your printer:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
M-F, 9:00am to 8:00pm Eastern Time
Jan 10, 2009 | Computers & Internet
Document to memory before sending
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step. http://www.brother.ca/en/products/pdf/manuals/MFC8220-UG.pdf
Sep 06, 2007 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
172 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
