Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Set your router to the DMZ?
How do I set my router to the DMZ.
  • Gateway Master
  • 6,487 Answers
You just need to access your router setup page then go to Firewall then select DMZ, To put a computer in the DMZ, enter the last digits of its IP address in
the IP field and select “Enable”. Click “Apply Changes” for the change
to take effect.
Posted on May 09, 2008
4 Suggested Answers
SOURCE:
  • 193 Answers
SOURCE: Setting the DMZ setting on my pelican router
sure first connect a pc through hard wired in the linksys and open a browser and type 192.168.1.1 and user name admin and password admin and login and in application gaming select it and select DMZ and enable it and put a ip address in teh range of 192.168.1.100 to 192.168.1.254 and save it and connect teh pc through that device and assign ip address statically on it login to that inter face and select wan setup to static and ip address which u entered in dmz on teh linksys exl 192.168.1.__ and subnet mask is 255.255.255.0 and default gate way is 192.168.1.1 and dns 1 or primary dns is 192.168.1.1 and save it
Posted on Jun 27, 2008
  • 31 Answers
SOURCE: XBL router problems
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
SOURCE: can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
Posted on Jul 01, 2009
TP-LINK dmz bug
even though my pc was set to DMZ port 80 was still in use for the web-interface. I've changed the router web admin port to 81 and now it is fine.
Apr 03, 2012 | TP-LINK TD-W8901G Router
NAT type is set to strict, I would like it set to open. Modem is a NETGEAR DM111P
What you have to do is go to your router settings!! You need to find DMZ settings !! DMZ Server allows you to set up a computer or server that is available to anyone on the Internet for services that you haven't defined. There are security issues with doing this, so only do this if you're willing to risk open access. If you do not assign a Default DMZ Server, the Router discards any incoming service requests which are undefined. This can be a security problem. You shouldn't check this box unless you have a specific reason to do so. Thats enough **** of that !! Then you need your xbox IP address and add that to the DMZ setting this will set your NAT to open!! Just be careful if not using a static IP address with your xbox that if router is turned off the xbox will asign a new one and you will have to re-enter the DMZ. Hope this helps
Feb 22, 2011 | Video Game Consoles & Games
How do i clear my port for forward settings? Recently I set up port forwarding for my xbox. However, thru researching im reading that enabling dhcp and dmz is all i need for a the bext xbox live experience
Access the router's built-in web-interface, and access the router's web-page where you "enabled" the port-forwarding. Then, "remove" or "delete" the settings.
Then, access the router's web-page that defines which of your computers/XBOX is to be placed into the 'DMZ' ("De-Militarized-Zone"). Put your XBOX, not your desktop, into the 'DMZ', to allow it "full" access to the Internet, i.e., bypassing the protection of the "firewall" that is inside your router.
Apr 07, 2010 | Dell TrueMobile 2300 Wireless Broadband...
How to configure dmz on linksys wireless n router?
  1. Log into your router. (If you need help how to do it let me know!)
  2. Go to th "Application & Gaming" tab.
  3. click on "DMZ"
  4. choose "Enable"
  5. Enter the IP address of the computer you want to put in the DMZ.
  6. Click "Save Settings"
Some notes:
  • Putting a computer in a DMZ is pretty risky, because all ports to this computer are opened. Make sure that all recent patches are applied and your virus software is up to date! A more secure solution is to use portforwarding. (See this site how to do that for a specific software for your router.)
  • Your computer should be set to a static IP. For two reasons:
  • A) DMZ will not work if your DHCP server (your router) assigns at one point a different IP address to your computer,
  • B) If a different computer gets the Ip address assigned that you specified in your DMZ settings, then that machine is exposed.
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | Port Designs Linksys Wireless-G Broadband...
Can anyone help me set up a dmz on this router(zyxel p 334)
Jul 01, 2009 | Zyxel Prestige 334 Router
Gaming
You need to set the correct address for DMZ (your PC IP address). You may also find that your PC firewall settings will need changing.
You shouldn't need to set DMZ for this, you can set port-forwarding instead, and then select the ports you wish to pass through for each IP address connected to your home side of the router.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Wireless router wnr834
An easier way of opening ports is to use DMZ, this will open all ports to one computer on the network. Go to the DMZ part of your wireless router, find out the computer's network IP address (192.168.1.x - x being your number) and enter it in DMZ and save your settings. Then take all the game related port forwarding settings out the router (don't touch DMZ after setting it up) and that should do the trick. Saves messing around with individual ports.
Sep 07, 2007 | NetGear WG602 802.11g/b Wireless Access...
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
896 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
