Question about Datamax Office Equipment & Supplies
Trying to calibrate labels on E4205 and having trouble, if I'm reading the instructions right, I'm supposed to hold down the F2 button and it will automatically calculate via a sensor, but it doesn't. What am I doing wrong?
Hope you found a resolution to your issue by now, but if not, there was a firmware update meant to address calibration issues. You can also do an empty calibration where you remove the media and hold the feed button until the platen roller turns, then load the media and do the quick calibration where you press and hold the feed button. I have also found that moving the media sensor towards the center of the media sometimes helps. You can also try moving the media sensor, do the Empty Calibration, then the Quick Calibration, tehn move the sensor back and do both calibrations again.
Posted on Jun 30, 2010
THE PRINTING IS NOT LINED UP ON THE LABELS THE FIRST ONE DOES AND THEN IT SEEMS TO LOOSE ITS ALIGNMENT
Label not aligning is usually due to the printer not being calibrated to the label length, Turn off the printer.
Hold the button down on the top front of the printer, Hold
Turn on the printer still holding down the button and wait for the printer light to flash, then let go of the front button.
The printer will now feed out several labels and calibrate.
Turn off the printer, then back on, now try feeding the labels, it should now line up perfectly.
Contact www.lancerlabels.co.uk if you have difficulty doing this
Home
Sep 30, 2014 | Zebra TLP 2824 Thermal Label Printer
Printout not align and faults indicates led lit up
The Media Sensor is not seeing the labels or is not configured for these labels. Check Media Sensor position and settings. The Fixed Sensor models have a small window for the sensor at the bottom of the printer, about 3/8" to the right of the left side. If the printer has a movable sensor, the typical position is either 1" to the right of the left edge of the labels, or in the center of the labels. Typical media sensor setting is "Gap Mode". Another common issue is that the sensor might have a piece of label or something stuck to it, covering the lens. Finally, there is a possibility that the reflectivity threshold may need to be recalibrated (see below). This can be difficult, although there are instructions in the Operator's Manual. If physical position/clear view of labels by sensor doesn't seem to be the issue, an easier way to deal with settings issues might be to Restore to Factory Defaults (see below).
Datamax E-Class Auto Media Calibration Procedure:
The 'Auto Media Calibration Procedure' allows the operator to
automatically obtain the optimum (TOF Low and TOF Delta) values for
a particular media. These values are useful for media that continues to
have troubles after Media Sensor has been manually calibrated (usually
preprinted media). This operation feeds 10 inches of media using the
current Media Sensor Calibration setting and calculates the TOF Delta
and TOF Low values to be used. Upon completion the printer will exit
back to 'Calibration Mode' flashing the PAUSED light if successful or
the FAULT light if not successful.
Note: Before calibrating, be sure the media sensor is set for the
appropriate media type, see section 4.4.2, also be sure the
printhead is latched down and the cover is closed.
To perform the Auto Media Calibration complete the following steps:
1. Load the desired media.
2. Hold the button while powering up the printer. Continue to hold
the button until the PAUSED light turns off then release.
3. Next press the button, (the printer will now calibrate to the
media)
4. The PAUSED light will flash 5 times to indicate a successful
calibration. The FAULT light will flash 3 times to indicate an
unsuccessful calibration.
Note: If you wish to discard your changes and revert back to the
previous calibration simply turn off the printer before Step 5.
5. Now you can save your changes and resume by again
pressing the + buttons simultaneously.
Datamax E-Class Reset to Factory Defaults Procedure:
With the printer off, press and hold the F1, F2, and F3 buttons while
turning the printer on. Continue to hold the buttons down until the
PAUSED light turns off. The printer will now be set to the 'Factory
Defaults'.
Jul 22, 2014 | Datamax DMX E4203 Printer
My printer keep saying"error condition
It sounds like you may have loaded the ribbon incorrectly.
Sep 22, 2011 | Zebra Z4M Printer
Labels aren't feeding through at right length
This sounds like a calibration issue.
Follow the instructions below to re-calibrate
Three readings are required:
· Empty: No media in the sensor.
· Gap (or Mark): Only the backing, notch, or reflective mark in the sensor.
· Paper: The label (with the liner attached) in the sensor.
To perform a Standard Calibration:
Step Operator Action Displayed Message Comment
1 (Media should be loaded and the appropriate Sensor Typeselected.)
2 Press the menu key.
Raise the printhead assembly.
MENU MODE
MEDIA SETTINGS
You are entering Menu Mode.
3 Press the enter key to enter
the Media Settings menu.
MEDIA SETTINGS
MEDIA TYPE
4 Press the FWD key and
scroll to 'Sensor Calibration'.
MEDIA SETTINGS
SENSOR CALIBRATION
5 Press the ENT key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the ENT key.
Remove the media from the Media Sensor then press any key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
Press any key to continue.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
Aug 19, 2011 | Datamax I-4208 Thermal Label Printer
I have a Zebra TPL2844...I have calibrated the printer by turning off, holding the button,ect. It still will not calibrate. The light will turn red everytime. The sensor is not reading where the labels...
im thinking you are probably right about the sensor. or they may just need cleaning. do you have a manual? if so it will probably tell you how to test the sensor to see if it is working. if not try www.zebra.com
May 23, 2017 | Zebra Eltron TLP 2844 Thermal Label...
Zebra S600 Printing
You have to program the tearoff.
See the manual or use a windows driver to end the value to your printer
Aug 24, 2009 | Office Equipment & Supplies
Hi, we have tbl 2844-z and trying to calibrate but the ribbon never starts at the right beginning of the label, how to calibrate?
To calibrate, press and hold the green feed button until it flashes 4 time and let go, it will reset the factory defaults and calibrate. If the print is starting lower on the lable than you want, you will need to adjust the label layout from the application.
Jul 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844-Z is faded on the right half when it prints
It probably needs a print head adjustment or calibration.
Here is a link for the user guide,(it takes a minute to load and display) you will find cleaning and diagnosing tips :
http://www.systemsprintmedia.co.uk/downloads/ZEBRA%20TLP%202844Z%20MANUAL.pdf
If your zebra label printer is not feeding to the next label correctly it may need to be calibrated. Follow these steps to calibrate the printer:
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the “Out of Dump” message on it.
  7. Printer is now ready for use.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
996 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
