Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door not closing, bouncing back up when reaches sensors
  • 504 Answers
IF THE SENSORS ARE MOUNTED TO THE TRACK THEY COULD MOVE OUT OF ALIGNMENT WHEN THE DOOR CLOSES. WATCH TO SEE IF THE LED LIGHTS ON THE SENSORS GO OFF AS THE DOOR CLOSES.
THE TRACK COULD BE TOO TIGHT CAUSING THE DOOR TO REVERSE WHEN IT BINDS.
IF THE DOOR IS TOO TIGHT WIDEN THE TRACK AT THE FLOOR. YOU MAY NEED TO CHIP CONCRETE IF IT IS CAUSING THE TRACK TO BE TIGHT.
HOPE THIS HELPS
Posted on May 26, 2010
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
Chamberlin garage door opens to top limit bounces back to return down about 6 inches and then returns to open limit. What adjustments are neccessary?
The limit switch of both the sides are not reached. The drive must be realigned to work till the door closes fully so as to touch the limit swittch to switch off.
Similarily the open door must go to the extreme point to cut off with the activation of the limit switch.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain garage door will not close
See if both sensors stay lit until the door reaches the closed position.
If either light is off or flickers the door will go back up. Try aiming the eyes very carefully. If they are aimed properly. Check the wiring if you move the wires and the light flickers you have a bad connection. If the lights don't come on you may have a broken wire.
Mar 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door goes back up once it reaches the sensors. The sensors are seeing the door (metal part) as it crosses the sensor and going back up. I have tried adjusting the sensors to point away from the...
IF THE DOOR INFACT BRAEKS THE BEAM THE EYES NEED TO BE MOUNTED FURTHER AWAY FROM THE WALL. ABOUT 2 INCHES FROM THE ACTUAL DOOR HARDWARE.
IF THE DOOR IS NOT PHYSICALLY BREAKING TH BEAM SEE IF THE TRACK MOVES/TWISTS WHEN THE DOOR CLOSES THIS MAY TURN THE EYES OUT OF ALIGNMENT FAR ENOUGH TO REVERSE THE DOOR.
Sep 21, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
The passanger side sliding door on my 94 Crysler Town and Country had been working fine, this morning however when my daughter tried to close it the door bounced back open, and now the door will not close,...
I think something maybe blocking it from closing check really well around the door and near the sensors. If that doesnt work i think a sensor went bad and now wants to stay open. Its like a position sensor tells the door how far to go and when to stop.
Sep 08, 2009 | 1994 Dodge Caravan
My garage door opener reaches the laser beam and goes back up
Have checked to make shur nothing on the Door is sticking out into the path of the beam. Most door I know of are set so that anythig breaking the beam, while the door is in motion, will send it back up. the beam dosnt stop being looked at till the doors been all the way closed for a second or two.
You might want to look at the part of the door that reaches the laser just before it goes back up, it dosent take much to break the beam, a piece of string could do it.
Hope this Helps
Gem
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electric windows bounce back down when the y reach the top
if it just fell, it came out of its track.
if it went down slowly it must have a intrapment feature, that makes the window reverse when something it in the way.
if this is it ,the window will need to be adjusted
Jun 23, 2009 | 2001 Saab 9-3
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
130 people viewed this question
Top Chamberlain Car Audio & Video Experts
Vince Heuser
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
