Question about McCulloch Garden
40 cc model ms4016pav will run for about five minutes then die. After that it will start and die, start and die.
  • 3 more comments
  • dontbother10
    dontbother10 May 11, 2010
    Did you replace the fuel lines? Reply below please.
  • dontbother10
    Does it run for a few seconds only after the primer is activated?
  • gtsam May 11, 2010
    Nothing done yet. just didn't know where to begin
    After the initial run it will start and run a little bit but will not rev up
The problem is likely that the saw has been overheated. What happens now is that the engine loses compression because when it heats up again, the cylinder goes out of round. After cooling off compression returns to normal.
The block has probably been overheated which means the engine is junk.
Posted on Jan 16, 2013
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Does the primer bulb fill with fuel after several pumps? Make sure the carburetor fasteners are tight. Hope this helps!
Posted on Jul 23, 2010
Have a 11.5 hp engine on 30 in snapper, after 30 minutes or so it will cutout and die. I can clean the plug and put it back in START it and it will run good for 30 or 40 minutes and die again.
One question is the spark plug filed when you remove it? If it is change it..If not It sounds like you are having fuel delivery problems..where the float is sticking or dirty and not allowing the gravity time to keep the fuel supply up.try this, the next time it does that..do nothing and wait about five minutes..if the float is sticking or dirty sometimes the carb bowl runs out if fuel..this will allow a dirty or sticking float valve to slowly refill the bowl..if it starts after five min or so..that is what it is..the carb will need a good cleaning..if you are mechanically inclined...not a hard job just remove the bowl from the bottom of the carb and carefully remove the float and valve remembering the order you removed it...use some carb cleaner and spay the valve seat and clean the float valve...should be ok..good luck..
Jun 23, 2015 | Garden
Why is my True THAC-48 unit is not cooling?
need more info. is the condensor fan running? if not thermostat problem.if it is , is the compressor running or just makes a one time click a few seconds after plugged in? (after unplugged five minutes)... if this is the case it probably needs a new start capacitor (170 uf)..if the compressor is running the larger tube going in the commpressor should be cool about 40-50 after a few minutes .. if not then it is low on refrigerant..R-134 after 1995. or R-12 for older models.. now you also have inside fans and thermo buttons that can not be working.
Nov 09, 2013 | True THAC-48 48in Horizontal Air Curtain...
Runs until it warms up then dies
Check the fuel pump, fuel filter and fuel lines.
Mar 22, 2013 | 1994 Honda Civic
After driving 20-30 minutes I shut the truck off and it will start but then dies and wont start again for 40- to a hour
I have a similar problem. My engine shuts down after about five minutes..
Measuring the current into the distributor(ignition) reveals a jump in current from 3 to 40 amps.
The power lead is red on white and the ignition lead is yellow on black and goes into a connector under the dash where the ignition wire changes to white on black. Three different wiring diagrams give no clue to how this problem is caused.
Also, the starter is good for only a few turns after the engine warms up.
Mar 20, 2013 | 1986 Mazda B-Series
1995 jeep grand cheerokee laredo 6 cyl. randomly dies then takes anywhere from five minutes to hours to restart
The only component I know of, that shuts a Jeep off while idling or driving 40mph down the road, is a bad crank sensor. Usually when it starts going bad, it will sporadically shut off, like yours does. Eventually, it will just die and the Jeep will not start at all. Have it tested and replaced, if necessary.
Mar 15, 2013 | 1995 Jeep Grand Cherokee
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
IT STARTS BUT DIES AFTER ABOUT 5 SECONDS
what kind of saw is it? and if this is the problem u might have over primed the button on the side thats part of getting the saw started and maby flooded the carb and could be the reason why its hard to get it goin. Doesnt take much to flood a small motor. Oh and almost forgot do u have the right mixure of ur fuel? for my saw its 40:1.
Jun 04, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Fuel system
Check the fuel system, chenge fuel filter. clean the fuel tank.
Oct 16, 2008 | 1994 Toyota T100
Garden Logo
123 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
