Question about Sharp R-1870 Convection/Microwave Oven
The turntable for my Sharp R-1870 has stopped turning. The table on/off button does not make any difference The microwave still work,s but doesn't cook as evenly in the convection setting. Is it possible & cost effective to repair?
    President:
  • 1,335 Answers
It sounds like the parts and repair will be more costly than replacing the unit. How good are you with electronic repair?
Posted on May 11, 2010
No turntable for sharp R-1870
The turntable motor will need to be replaced, a common issue with most brands.
Apr 21, 2012 | Sharp R-1870 Convection/Microwave Oven
Turntable does not turn and microwave does not heat
Is the turntable not turning a result of no heating? If it is I expect you have a failed door interlock switch.
Jan 20, 2011 | Sharp R-1870 Convection/Microwave Oven
My sharp R-953 turn table turns slowly when you put some thing on it ,it stops turning
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 13, 2011 | Sharp R-1870 Convection/Microwave Oven
Have a Sharp microwave R-1870 turntable not spinning an not heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 05, 2010 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp R-1870 Convection/Microwave Oven Logo
179 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
