When I lift the diverter valve for my Grohe shower wand, to divert water from the faucet to the wand, it doesn't engage all the time. If I put a little side pressure on the valve when I lift it, it will work some of the time. I can't figure out how to get the valve handle off to see what is slipping. Any recommendations? thank you
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
SOURCE: I have a movatio shower head with a grohe allure
not the shower head ..its the hot and cold handles...
SOURCE: Have Moen tub facet with a single handle and
I have already replaced my MOen cartridge on brand new faucet and still drips. Just like yours does.
SOURCE: I Have 25 year old
Have you tried simply cleaning out the aerator?
Unscrew the aerator from the bottom of the faucet and clean out all of the debris on the screen and inside the fitting, then replace.
