Question about Dryers
By mistake i hit the circut breaker and since i put back, the dryer does not heat up. only cold
  • Dryers Master
  • 43,501 Answers
Hi, Sometimes the circuit breaker will not reset properly turn it off again and reset it hard.... If you have a gas dryerby mistake i hit the circut breaker and since i - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If by mistake i hit the circut breaker and since i - 2_bing.gifef="http://www.fixya.com/support/t4726170-load_takes_more_one_cycle_dry#">dryer is electric2_bing.gifby mistake i hit the circut breaker and since i - 2_bing.gifere could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gifby mistake i hit the circut breaker and since i - 2_bing.gifef="http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 13, 2010
Gas dryer pops circuit breaker
Number 1 Do NOT! use this dryer until it is fixed, it a a fire hazard. You will need to get the entire power circut checked for shorts. Make sure the motor has been checked under the same conditions as it is used in the dryer, with a capasitor and changing directions etc.
NEVER EVER !!! Change a Circut breaker with a higher value than the one which is there. You will burn the house down. This is a serious fire risk. The power cables over heat and arc then burn, if the breaker is not right.
Feb 01, 2014 | Dryers
Gew9200LW duet dryer
If this is a 220 VAC dryer use a voltmeter at the wall plug. Chcking from common, usually the leg with the angled blade, to each of the hot legs, each with the straight blade. You need to have 110 VAC in both of these. If there is only 110 at one of the legs the motor will run but the element will not heat. If you find only one leg has 110 VAC try a new circuit breaker in the breaker box. If the breaker is bad it will appear to reset, but still not send current. If you have 110 on both legs check in the dryer for a burned off wire at the timer or element.
Jan 06, 2014 | Dryers
No heat
most likely cause is element next would be circut breaker or fuse, or thermo fuse
Sep 20, 2010 | Kenmore 62972 Electric Dryer
3 years old, totally dead dryer
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
Mar 15, 2010 | Bosch Nexxt 500 Dryer
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
Have a dedicater 220v 20a circut break to a clothes dryer. The only work done but the electrician was a new main grounding wire and removed conduit and wiring in the basement. Now the breaker opens after 1...
Typically, a standard electric dryer is 30A 240V unless it is natural gas. If the wire is #10awg then you can put a 30A circuit breaker on it. If the wire is #12awg then you DO NOT want to put a larger circuit breaker on it or it over heat the wiring in the wall. If it was a short in the wiring the circuit breaker would trip immediately even with out the dryer plugged in. If it was a grounding problem the circuit breaker would not trip at all, it would just electrify the dryer chasis. It sounds like it is an over current problem, drawing more than 20 amps through the circuit breaker, or like the dryer has an internal problem that is causing the circuit breaker to trip.
Nov 21, 2009 | Gb Electrical 100 Amp GE Load Center
Where is the circuit breaker or fuse on a Kenmore Gas Dryer?
no heat usually means your only getting110 volts into your dryer.....you need the full 220volts to run heaters....with voltage meter you checkwires on the plug OUTLET...or inside back cover REDwire to WHITEwire =110v.........BLACKwire to WHITEwire =110v.....REDwire to BLACKwire =220v. you probably have aBAD 220V. 30 amp circut breaker..or if still using FUSES one is burnt out (In house electric panel) or burnt off RED or BLACKwire in back of dryer.....
May 09, 2009 | Kenmore 63942 Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
