Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
MFC-8660DN JUST INSTALLED WITH C.D. SMOOTH INSTALL, BUT IT DOES NOT PRINT. FAX ONLY SLEEP.
  • Brother Master
  • 19,396 Answers
First check all cable, and check that you are using the usb cable (if you want local printer connected to pc), and not the network cable to connect to the computer.
If it is not that, this probably happened because you connected the printer before installing software.
You need to remove the printer from 'installed printers' in control panel on xp or in printers on Vista. Then unplug the printer from computer.
Restart computer.
Install again printer disk.
Plug printer in usb only after installing software, or when required.
If asked restart PC.
In this way it should work.
regards
Posted on Mar 28, 2008
    Genius:
  • 3,422 Answers
HI,
Click HERE to download the user's manual.Please refer the troubleshooting steps.
Click HERE to download setup guide.
Goodluck,
Please don't forget to rate the solution.
Hi i have a brother called MFC 8660DN, he is not recieving or sending any fax since this morning and i can't find the problem.
Try these things below to narrow down the problem.
  1. Plug a standard phone into where the fax line is plugged into to check for dial tone. if you have dial tone try replacing the phone line between the wall and fax. If not you have a phone line issue.
  2. Make sure the printer is actually responding to print commands from a computer, this could indicate a hardware issue if it does not.
  3. Check the ink levels. If the printer thinks it is out of ink then it will not print faxes.
I hope this points you in the right direction Regards GM
Apr 26, 2011 | Brother MFC 420CN All-In-One InkJet...
How do i change the settings on the fax such as company name?
Press MENU and then the 0 (Zero) key. That will take you to the Initial Setup menu, where you set name. phone number, etc.
BillB
Jan 29, 2010 | Brother MFC-8660DN Network Mono Laser AIO...
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
I have a Brother MFC-8660DN. When I receive a fax
That type of problem comes from either the drum or the fuser, the best way to check is to unplug the machine while it's printing and see of the shadow is on the paper before the fuser, if it is then you need a new drum, if not the fuser is the culprit.
Oct 28, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Yellow Light on Brother 8660DN will not stop blinking
swithc off your sutem and other assiciates .
frame the climax and do it later
Jul 24, 2009 | Brother MFC-8660DN All-In-One Laser...
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
How to print envelopes
Open the manual feed tray door (that is the door on the front that has the "Brother" logo on it. Narrow the feed tray guides to filt your envelope. Envelopes feed it with flap side up and to the left.
Dec 30, 2008 | Brother MFC-8660DN 5-in-1 Laser...
I have the Brother MFC-7820, I just purchase a laptop with a Windows Vista. I am unable to use the printer. What do I do?
23/Feb/ 07: Updated the Brother original driver(Full Driver & Software Package) for the following products to fix a driver installation problem: FAX-2820, FAX-2920, DCP-7020, DCP-8060, DCP-8065DN, MFC-7220, MFC-7225N, MFC-7420 ,MFC-7820N, MFC-8460N, MFC-8660DN, MFC-8860DN, MFC-8870DW, MFC-9420C
And here is the link of the updated full driver and software package. After you download this, you should be able to run the MFC 7820 with your new laptop=)
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
