Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How to remove a carburetor from a 18 hp briggs and stratton riding lawn mower
SOURCE: i need to how to connect the throttle to the carb
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
Posted on May 06, 2009
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 53 Answers
SOURCE: I have a 2003/4 craftsman riding mower, 23 hp
sounds like the stator under the flywheel is bad that is what charges the battery
Posted on Jun 11, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
How do I replace the Connector-Hose Fitting on the Walbro carburetor?
If it is the following connector it is a press in fit. Carefully remove the old brass fitting from the carburetor. Note: these are not swivel connectors as most users think. Position it at the angle needed before pressing the new connector.
May 21, 2015 | Yardman Yard-Man 12.5 HP Manual 38-in...
What is the torque sequence on a 18 hp. v twin motor briggs and stratton motor
If your talking about the cylinder head bolts. I don't know the exact sequence but I was a truck mechanic for forty years and went by the rule of thumb to start in the center and work towards the ends. That way you avoid a buckling o9f the head.
Jun 16, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
Where do i find the spark plug to change it
there is a fat black wire next to the tin valve cover the plug is under the boot on the end of the wire
Jun 30, 2012 | Briggs & Stratton Briggs Stratton...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
May 23, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lawn mower / could not find a product on lawn mower, but a car mechanic can tell me.
http://www.google.com/search?q=18+HP+briggs+and+stratton+SERIAL+NUMBER+LOCATION&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a TRY THIS.RICHARDM69
May 20, 2008 | 2001 Ford Excursion
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
268 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
