GPS Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1994 Lincoln Town Car. After running for a few minutes the blower for the heater, AC , defrost jumps to full speed and stays at full speed. You have told me that the blower control programmer should be replaced. What is the best way to reach this unit ?
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on May 19, 2010
Master
Level 3:
Answers
6993
Questions
Helped
1700080
Points
1261
is this a car problem or a GPS problem?
Please let me know.
Bye for now
1helpful
2000 lincoln town car heater blower runs all the time. I changed the climate control and still runs all the time
They are designed to run on low all the time. This is to keep the cabin pressurized to avoid dust from the outside getting in while driving. If it is on another speed other than low then maybe the speed control is the culprit.
1994 chevy kodiak with Cat 3116. Heater/AC blower shuts down
you should make a diagnostic to know what happened to your car
of course you need an auto diagnostic tool : http://www.chinasnoy.comand you can find all kinds of tools in chinasinoy.com
2helpful
2000 Lincoln town car. Heater fan is full on at full on position. Any other setting the fan is off. No speed control.
When one or more speeds on your heater/AC aren't functioning, the problem is usually the blower motor resistor. It's usually located near the firewall on the opposite side of the heater core.
1998 Lincoln Town Car. Defrost/AC Fan blower suddenly stopped working. Is there a particular fuse that controls this? None are marked as such. Thanks!
I unpluged (on my 98 T.C.) the blower motor to check that it had power to it (it did). Pluged it back up, and it started working again, and has been for weeks now. david...
6helpful
Blower fan not working for heat and AC. THis is on a 2000 Lincoln towncar
This sounds like a BSC blower speed controller. it is located outside on the a/c case just below the heater hoses. to diagnose just wiggle the connector with the key on engine off, you should hear the fan come on, then replace it.
3helpful
How to fix 1999 lincoln TC heater/AC fan speed. Speed is intermittent or not blowing at all. Fan sometimes blows at full speed then may start to turn on and off. Sometimes it does not blow at all.
You have a problem with the resistors on your blower motor. 95% of AC/Heater blower motors are located under the glove box in the passanger foot well. When you remove the motor you should see a resistor plate. Resistors are not servicable and will need to be replaced. This is a relatively cheap part, that you can replace yourself if your handy, if not take it to your local tech.
3helpful
2answers
Cannot control my AC blower on my 2001 Lincoln
sounds like your switch contacts are shorted closed.. try disconnecting the switch for inspection and use a volt ohm meter to inspect switch across contacts...
7helpful
1994 Lincoln town car/ no fan control on ac and heat
I aasume you mean blower motor for heater/a/c system.
Does it work on hgih speed only? If yes, replace resister.
Is this manual a/c or electronic?
Here is circuit for manual. check these three fuses first. 1, 17 & 10 in fues panel behind dash or kick panel by driver's knee.
If you have electronic, you may have a bad "blower motor speed controller". Get used at car-part.com. page with asterisk is lowest price. New at tascafordparts.com
2answers
96 lincoln town car ac fan doesn't blow
check the blower motor relay and resistor.
2answers
1994 lincoln town car will not stay running
Idle air control valve.. clean it (mechanic will for just a few dollars) the other culprit would be the mass air flow sensor.. it is located in the air intake tube coming from the filter box.. its round and has one plug in.. if you take it out you will notice the inside looks alot like a honeycomb. its not cheap but I am 99% sure that is what you need....
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
