Question about Husqvarna 28CC Handheld BlowerVac
Husqvarna Leaf Blower won't start
I was running leaf blower and it stopped. I thought it was out of gas. The gas was low, not out, so I filled it up. It has not started since. I have cleaned the plug. The plug is wet, so I believe it is getting gas. This model has a stop switch and I wonder if this switch is stuck on "stop"? Is that possible?
  • 198 Answers
Yes, it is. i suggest checking to make sure the plug is firing--you can check by removing it, plugging it back into the plug wire and resting the threads of the plug on any ground--usually right outside the spot where the plug screws in. have someone pull the cord while you see if the plug fires. DON'T touch the plug while the engine is being cranked. also, even if you see a spark, it may not fire inside the engine. if the spark is weak, you may want to put in a new one.
Posted on May 12, 2010
4 Suggested Answers
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
jdlipscomb41
  • 157 Answers
SOURCE: what is the ratio of oil to gas for Husqvarna leaf
i mix my husky and stihl the same 50;1 ratio that way i know it has enough oil not to burn the piston
Posted on Oct 26, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Husqvarna leaf blower won"t start,changed the plug and gas,now what
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
Nov 06, 2012 | Husqvarna 28CC Handheld BlowerVac
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Gas blowback through the air filter
A certain amount of "spit back" is not abnormal in a 2 stroke engine without a reed valve (like the engine on your 155BT). If the engine runs well I wouldn't worry about it. However, this condition can be aggravated by an engine with a worn or stuck ring (other symptoms would behard to start and low power) or by running the engine at wide open throttle without load (pretty much impossible to do with a blower unless you block the outlet or have severe fan damage).
Apr 25, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Husqvarna 28CC Handheld BlowerVac Logo
2,061 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
