Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Can you please tell me what the carb adjustments are for the Poulan 18in. wild thing chain saw?
    President:
  • 2,220 Answers
"L", "H", and "T" adjustments are all explained on the link. It is a very good carburetor setting procedure.
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 11, 2010
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2375 will not idle
This sounds like a simple carb adjustment issue, however there is a special tool required to adjust the mixture, part no. 530035560, once you have the tool richen the L scerw on the carb by unscrewing it by 1/4 turn out, before making this adjustment, try just increasing the idle speed screw on the carb, this requires just a normal screw driver, do not increase it to the point ehere the chain is moving on idle.
Mar 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carb adjustment for a Poulan Wild thing 2375
Start at 1.5 CCW from lightly seated then tune for performance like this:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
May 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
359 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
