Question about MSI MS-6378 Motherboard
None of my pariphials are working. I used my PC yesterday morning and left it running all day. I tried to use it that evening and it was like it wouldn't wake up. I manually shut it down and when it restarted my keyboard, mouse and monitor did not work. What do I need to do next to troubleshoot this issue
  • paseo1997 May 11, 2010
    What exactly does it do when you turn it on, is there hard drive activity or do you just get fans and a power light, are there beeps?  Is there a windows startup sound?  Do you see anything at all on the monitor?  Are you using onboard video or a video card?
  • 2,229 Answers
This is what I would recommend:
First, unplug the computer from the power outlet. Then re-plug it and try to start it. If nothing seems to work, but you have power (you can hear the fans start and hear the hard drive spin up, you can open the case and disconnect everything BUT the CPU, memory, and video. See if it starts. It should start up with video and give you an error saying something about no boot device. If this is the case, then start plugging things in starting with the hard drive.
If it doesn't work your power supply may be bad. If you have another to swap out, that's good. If you don't, then you really can't check it without a power supply checker.
If this doesn't work you are probably looking at a bad motherboard, bad CPU, or bad memory.
Posted on May 12, 2010
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
Only the printer led is lit
Are there any lights on? If not, then have you checked the power supply, and the wall sockets. Sounds like that may be your problem?
Feb 25, 2010 | Draytek Vigor 2910G Dual WAN secure...
Can not start my computer
Plug the unit directly to the ac outlet if it is plug into a surge protector. See if it boots. Did you shut it down yesterday or was it left running? Any bad weather last night? You could try another computer memory and see it is the memory. Not sure what it could be at this point. What type of system is it?
It could possibly be a bad power supply.
I hope this helps.
Feb 17, 2009 | Acer Aspire™ T180 PC Desktop
Failing to boot
try booting in safe mode ( hit F8 after post screen ) and try a system restore, if that doesn't work you'll have to use your recovery disk and choose the option "repair my pc"
hope this helps
leecom72
Nov 12, 2008 | ASUS Eee 4G Notebook
Black Screen
hi, try boot to safe mode, check the display properties, settings and the refrsh rate. if not solved, reinstall the graphics controller driver..
thanks
Aug 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Left & Right Mouse Click = opens up properties
If your mouse is under warrenty, nonthing to worry. It is an assembling mistake.
Dec 09, 2007 | Genius MousePen 8x6 (MOUSEPEN8X6)
Zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Mike
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
MSI MS-6378 Motherboard Logo
55 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
