Question about Maytag Atlantis MAV9501E Top Load Washer
Motor hummed and smoked, smelled electrical - Maytag Atlantis MAV9501E Top Load Washer
  • 10,319 Answers
If the motor smells foul it is fried and needs to be replaced
Posted on May 12, 2010
Smoke and electrical smell coming out of motor
Sounds like your "brushes" will need to be replaced. Please see the attahced video for step-by-step instructions.
http://www.youtube.com/watch?v=tECeZi6IfvU
Mar 05, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops...
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Oct 02, 2010 | Kenmore Dryers
My mowers blades are not turning but the hum of the motor is there and it has a burning smell with smoke coming out of the motor housing unit ...help
It sounds like bearings are seized and need to be replaced. Too much attempted use will burn out the field windings and a rewind or new motor will be needed - both costly.
Sep 20, 2010 | Electric Lawn Mower
Wiper blade motor smoking
If it's damp and cold and the motor is smoking a bit it may just be wet (if it is working well otherwise) If it's dry and smoke is coming out of it, there is a short inside and it needs to be changed. In either case, if the smoke smells electrical (steam does not smell) change it as soon as you can because the additional amperage needed to run it will also damage control components upstream of the motor.
Feb 09, 2010 | 2006 Jeep Grand Cherokee
Frigidaire window unit with heat and a/c smoke & burning smells
Hi, Anytime you turn a unit on like this and it smells and smokes, something is wrong. Did it smell as though it was electrical burning? Usually the blower motor is the first motor to go as they collect all of the return air and dust from the air and clog up the windings. They get hot and start to smoke, and you will know due to the smell of electrical wiring. I would turn it back on and see if it starts up and runs. If the motor hesitates in anyway, turn it off, or unplug it.If it is wired directly into a box, find out where the breaker is. If you are in fear of it catching on fire, call a air conditioning company out. I have seen them smoke like crazy but never had one catch on fire, never. I would turn it on, it will trip the breaker if the motor fails. Just watch it closely. If you can pull the front cover off and then turn it on, you may be able to see where the smoking is coming from, a motor ect.
Sincerely,
Shastalaker7
Dec 30, 2009 | Heating & Cooling
Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
Dec 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Bunning smell.
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Jun 16, 2008 | Vacuums
K45 started smoking while mixing cookie dough
There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
Dec 14, 2007 | Food Mixers
Maytag Atlantis MAV9501E Top Load Washer Logo
93 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
