I have a techdisplay tv model 1910CB and I can get sound but no picture. When I push the source button on the remote and come to the TV mode I get nothing until I push the volume button. The built-in DVD player works fine- both sound and picture.
jomaru
  • 337 Answers
SOURCE: Cannot get tv to switch to different source
You do not mention if you have unpluged the tv from the wall,is the easiest thing to try,if the set resets and still does not open the tray you can still force it open it manually but very carefully just to remove the dvd,if you can not force it open by pulling evenly in both extremes of the tray and you feel the dvd still is not coming out even with the tray open,dont go further and get help from a servicer,we do not want to break the mechanism.(set should be unplug )You can also remove the back cover and see if the main conector to the dvd player can be unplug,if it does you can leave it unplug and try turning the set on.This information might help you make a decision but the best solution will be to disassembly the dvd and remove the stuck dvd without forcing anything.The set is faily new and is worthed the repair.Let Us know how it goes.
Posted on Oct 26, 2006
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
  • 905 Answers
SOURCE: No picture under any source, TV, DVD, PC etc.
if you have already tried resetting and unplugging for a while , then something has happended to the video proocessing board inside the unit. it will need to be tested to determine the exact cause of the failure. if you have a warranty I would use it, otherwise you will need to take it to your local repair shop.
electech
Posted on Oct 26, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
Toshoba tv dvd combo picture on my tv will not work but picture on the dvd works great
I assume you mean you have a Toshiba TV with a slot for DVD play also. You don't say whether your TV is connected to a dish, cable box or antenna. Regardless of which it is, the fact that the TV produces a good picture on DVD but not on regular TV means one of two things: Either you have the TV hooked up incorrectly OR you do not know that you must change the SOURCE from DVD to TV to get a picture. That is done on the remote with the source button. Typically, the remote will have DVD, TV and AUX (one or more) as you cycle through them by simply pushing the source button again and again, If that doesn't work, you've got the TV hooked up incorrectly and/or it just happens to be set at DVD for the source. Normal hookup would involve HDMI out from the cable box, dish or whatever to HDMI in to the TV. Play with the remote "source" button. You'll figure it out. . .
Jul 02, 2017 | Televison & Video
I pressed the VGA button on my remote and lost my picture.
Find the button that relates to the input you want to view. IE "video" "composite" "s-video"
Or simply try any of the input buttons until the picture returns.
Also try simply hitting the VGA button again.
If none of that works, please let me know the model number of the tv and the input sources you are trying to view.
May 02, 2008 | Televison & Video
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
What is the remote control code for techdisplay, model # 1910CB
093,018,094,087,099 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
May 08, 2013 | Aiwa VX-T1470 14 in. TV/VCR Combo
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
First time to operate indicater light comes on reacts to remote but no picture or sound 42 philips flat tv
First red light normal
Now select channel or other source from remote with full batteries or pushing buttons left down side of TV. Red light is only stand-by
Apr 28, 2009 | Philips 42 in. Plasma TV
No signal or weak signal
Sorry I see the model,
hold the Menu button on the TV (not on the remote) down for three seconds.
Note: Shop Mode is activated in the same manner: Pressing and holding the Menu button on your TV for three seconds. To avoid accidentally setting your TV to Shop Mode, avoid pressing and holding the Menu button on the TV for three seconds or more.
Sep 21, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
