Question about Amana ARB1917C Bottom Freezer Refrigerator
Freezer works, not fridge (no air from vent).
My Amana refrigerator has a problem. Today, the electricity went out while I wasn't home. When I got back, the electricity was restored so I don't know how long it was out. I opened my fridge and noticed that it was not working (no air from the vent) and that the temperature had dropped! The freezer section was working though, everything was still cold and I feel cold air from the vent.
I don't know what the problem is, but I unplugged it now and will let it stay for 24 hours.
Can anyone help? Thanks!
  • Padme Amidala Jun 23, 2010
    Tested timer and it was functional. So I figured out it was the defrost thermostat. Bought a new piece for about 20$ and now there is no more ice on the back of the freezer coils! I had to open the freezer's back wall and the thermostat was clipped to a metal wire on the top right of the wall. Yay! I saved my fridge for only 20$! I hope this helps someone out.
catriver
  • 878 Answers
SOURCE: internal water leak Amana AT5518SW
King, you probably have a defrost drain port that is frozen over. When the unit goes into defrost it's running through the air damper instead of going out the drain line. Therefore you get water into the refrigerator section. You can verify this by removing the evaporator cover in the freezer and checking the drain hole. You can clear it by running hot water into it. You will have to remove all the built up ice from water that did not drain in that area...Catriver..post back.
Posted on Nov 13, 2006
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
landsend
  • 1066 Answers
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Posted on Mar 22, 2009
The fridge is at 64 degrees and the freezer is working well. Coils are clean.
In most fridges, the cooling coils are in the freezer section. The other section is cooled by air flowing from the freezer section.There should be a valve/vent/knob that allows more or less air to flow from the freezer. Adjust this to maximum cold to see it the temp changes. Or is 64 degrees too cold for you?
May 06, 2012 | Amana ABB1927DE Bottom Freezer...
Refridgerator side by side not getting cold
When we had this happen, the air vent between the freezer and fridge side was blocked with ice and wasn't letting the cold air come thru from the freezer. That's what cools the fridge. Our vent was up at the top between the two.
Jul 17, 2011 | Maytag Refrigerators
Freezer is working, refrigerator is not. have temp turned all the way up. it appears to b silent... help
Typically, the fridge gets its cool air from the freezer via a vent. If this vent is blocked, the fridge won't cool. If you don't see any obvious obstructions (e.g. a plastic bag fallen behind the racks) then it's possible the vent has clogged with ice. To melt the ice, simply unplug it for 12-24 hours. Use a cooler to store your perishables.
If this doesn't work, then the vent must be dismantled to determine what's blocking it.
Mar 05, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Hi, my amana freezes my food in the refrigerator....
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..It may be stuck open letting in too much cold air.
Aug 15, 2009 | Amana Refrigerators
Fridge not getting any air, freezer is working
I have a Kenmore w/ freezer on bottom. The top vent in the fridge is ducted to the freezer and is supposed to blow air. Mine was not.
I removed all the frozen goods and took off the back panel (inside to unit) which had a little ice on it. Underneath the panel was a solid wall of ice......including the motor which is supposed to blow air up to the 'fridge. I'd bet a beer that is your problem as well.
The ice seized motor will not be harmed because it is resistance loaded.
The best part is with a blow dryer and some elbow grease...the fix is free! I hope it helps.
May 27, 2009 | Amana ABB1927DE Bottom Freezer...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ARB1917C Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
