Question about Asko T700 Electric Commercial Dryer
Starter on dryer does not start dryer and no heat
Hold starte switch and dryer works but no heat
  • Asko Master
  • 2,605 Answers
Hello and welcome to Fixya,
have you checked the manual reset hi-limit cut-out at the back of the dryer ? It`s located on the back panel about 1/2 to 3/4 the way down and will look like a small round black rubber button. Push it to see if it "clicks" and then try your dryer.
**What to look for if it`s tripped...
1) Plugged venting - make sure your venting is clean and clear of lint or un-obstructed where it exhaust`s outdoors.
2) Plugged lint screen - ( part # 8061812 ) This is especially relevant if one uses fabric/static sheets as they contain wax...especially lesser name brand sheets. You can clean the lint screen by removing it from the door and with some mild soap and hot/warm water wash it...an old toothbrush works well for cleaning it. Careful not to rip the fine screen.
3) The blower wheel/fan impeller ( part # 8055200 ) attached to the front of the motor which moves the air through and over the clothes in the drum may be loose, broken or covered in lint, hence causing the hi-limit to trip.
4) A faulty heating element ( part # 8063808 ) can also cause the hi-limit to trip as well. If the element is shorted to the casing it will not cycle "off" via the 115°C (part # 8008807 ) cycling thermostat, thus cycling off via the hi-limit 150°C ( part # 8008487 ).
Let me know how that works or if you`ve already tried that. If it is tripped, resetting it may only temporarily resolve your problem since it is usually tripped due to venting or heater issues.
good luck.
macmarkus :)
Posted on May 12, 2010
  • ccingraham Dec 06, 2010
    Where is the heating element located? Do you have a picture or diagram to share?
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
I need help. Our dryer control currently works and when we push and hold the start button it doesn't start. lights work on control panel. door switch works and power is fine. last time it was used it smelt...
maybe the motor for the dryer, is this a even heat? if so here is a website:
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
if not an even heat here is another website:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer start button
The motor switch is not switching over. Either the switch is bad or the dryer is not tumbling fast enough to activate it. Eric
Aug 08, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't start unless I slam the door
Not normal. Check door switch. As a test you can jump it out to see if the dryer works then. if that does not help then , I i would consider replacing the starter switch.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
Asko T700 Electric Commercial Dryer Logo
216 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
