Question about American Range AF45LP Deep Fryer
Leaking from oil holding pot
I have a AF-45 which has been leaking from the front and rear of the oil holding pot. I don't know how to fix this problem except for to trash the unit and buy another brand. Can someone help with a repair for this - it has caught the unit on fire twice in the past year
    Problem Solver:
  • 11 Answers
Using dyed water, locate leak(s), go to a welder that does stainless steel and get fixed. If leaks are detected where thermocouples pass thru tank, remove and re-seal fittings.
Posted on May 13, 2010
Engine light comes on
sounds like you need to look at were it is leaking so the light don,t Come On Cause you might need to replace Oil Sending Unit Plug But first Look For the Leak did you change the Oil After Bying it OR Did It Just Happen ?the Light Comes On to Worn You Something IS Wrong So it,s Saying look At ME I,m Leakin So Fix Me Ther Ya go let Me Know What it was Thank,s For your time
Mar 04, 2015 | Cars & Trucks
My 2002 cadallic escalade is leaking oil I don't eant just anyone to drop my transmission to fix it, but is it worth it at the age of the car?
This all depends on how much oil you are loosing and how many miles are on it, if you like the truck and it is a bad oil leak then repair it , but if it has a lot of miles and needs other costly repairs then do not, this is a job that will run about 600.00 depending on what is leaking. for example is it the rear main seal?
the transmission may be on the way out who knows, thinking over and go from there.
Jan 16, 2013 | 2002 Cadillac Escalade
Gasoline / oil leaking from crankcase
hello p, the leak is coming from the rear crankcase cover which is located in front of carb, the screws may have loosened up or the pencil lead thin gasket has a crack, remove the air filter cover and carb,the four screws holding the cover on and you will see the gasket,not much of one but it is there,as far as i know i have never had a front seal leak,oh when the carb leaks it seems like the crankcase is leaking,so check it good,hope this helps,
Jan 17, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hi i have a 1994 dodge caravan it is leaking oil can this be fix im worry that we would have to save money for a van for my kids thanks
The Chrysler minivan products all had leaking problems. I have had 5 or 6 different Dodge or Plymouth minivans from 88 to 99. How bad is it. The most common thing is Valve cover leaks. Front and rear seals in the engine leak as well as the oil pan gasket. If its leaking a little bit at a time open the hood and look at the front and rear of the engine. Do you see grease and oil that has gone down the sides of the engine? Do you see a lot of grease on the engine with some clean streaks going through it. You may be able to see where its leaking from. If you know someone that knows what their doing have them change the leaky gasket/s. If not you can probably have it repaired for less than buying another van unless other things are seriously wrong with the van.
Hope this helps... Dale
Apr 21, 2011 | 1994 Dodge Caravan
Ford Explorer Sportrac 2001. some kind of oil leaking from the backend in the middle of the back tires.just wondering what it was and how to fix it
If the leak is in the middle facing the back of truck most likely the rear end (differential) cover or gasket is leaking. If it is leaking in the front of the rear end it is most likely a rear pinion seal. Spray brake & parts cleaner to clean area. Let it dry & see if it is leaking in the front towards driveshaft or the rear towards rear bumper.
Sep 06, 2010 | Ford Explorer Sport Trac Cars & Trucks
2004 Explorer: Rear differential cover is leaking, how do I fix i...
put flat pan under the housing remove the bolts holding the cover usually 10 or 12 (1/2 or #12 metric) bolts? allow the rear end grease to drain... then scape off the old gasket clean with brake cleaner spray install either new gasket or form one with oil resistant silicone put the cover back on , dont refill the fliud for at least 12 hours if using silicone. Also check the front driveshaft rear end yoke seal....they sometimes leak making the illusion of a rear end pan cover leak...if that is leaking you remove the shaft carefully...remove the large yoke retaining nut, replace the press in seal...be sure retaining yoke nut is properly torqued when reinstalling .
May 06, 2010 | 2004 Ford Explorer
My Chevy 2002 Tahoe is leaking oil. They told me
this truck is equipped with an aluminum oil pan you could have 1 or several things going on... a stripped drain plug which is causing it to leak or it may be a leaking front seal or a rear main seal. If it is a front seal it is not to labor intensive. But if it is a rear main seal leaking it will require the transmission to be removed since the seal is a 1 piece rear main
Sep 07, 2009 | 2002 Chevrolet Tahoe
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
American Range AF45LP Deep Fryer Logo
520 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
