Question about Brother MFC-9420CN All-In-One Laser Printer
Loud and Grinding noise
I have the same problem. Replaced the OPC belt and it is still happening. Next I am looking into the ps kit2 which is reading 0% life after just under 2 years. If this is another "consumable" priced around $300, I will run screaming and never buy a Brother again.
BTW, my copies are striated, the color sux and is faded on the left side!
  • msss May 05, 2008
    We are getting a loud grinding noise. It is inconsistant. I have looked at all the internal components but don't see anything obvious. I thought that it might have been a new toner cartridge that we had just installed. We tried another cartridge but still get the noise. I am puzzled.
  • Anonymous Apr 04, 2009
    I had the sam problem as well, during my cartridges inspection I noticed that the gears on my cyan cartridge was jammed too. I replaced it and the noise has gone...
I had the same problem, except my 9420cn is just over 1 year old. The parts life section says everything has atleast 75% of it's life left. I checked the toner cartridges and found the gear on the cyan cartridge was jammed.
I replaced it and no more noise....
Posted on Feb 25, 2009
I have just browsed these boards so that I could vent...I just spent $500 for an electrician to come out and put my Brother MFC 9420CN on a dedicated circuit and line because I thought that it was not getting enough power causing the loud and grinding noise that you guys are talking about. The electrian, who was very patient and curious why his work did not solve the problem sat there with me and we discoverred that when the MFC 9420CN was connected to my computer via USB, the grinding noise occurred and the scanner acted strange. As soon as the USB cable was removed, it worked fine! What do you think, guys?
Posted on Apr 25, 2008
Loud grinding noise when I turn my steering wheel to the left and right
sound like a CV shaft,now you need to figure out which one LorR
Feb 07, 2013 | Cars & Trucks
Loud grinding noise under hood, oil like substance on a belt, Power Steering Stiff, has PS fluid
Almost sound like your rack and pinion cylinder has gone bad. I would start by cleaning the area real well to get rid of the oil. With the car running have someone sit inside and turn the wheels from left to right while you stand and watch to see if you can see oil leaking and from where and also to see if you can tell where the grinding is coming from. Please do not try to clean the engine with it running as you will get burned from heat and your clothes may become tangled in moving parts.
Jan 30, 2013 | 2004 Ford Escape
Loud thumping sound and the belt looks ok
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 25, 2011 | GE DCVH515EFWW Electric Dryer
Ge profile dpsr473evoww has a VERY loud squeeking, it's not the belt as it's been replaced. Sounds like the rear bearing. What are the details of the rear bearing I need to purchase for this model?
heatman101
Asker
Mar 09, 2011 | Dryers
2000 Dodge Stratus - loud grinding squeal noise coming from engine - belt area - belt seems to be turning. Loud noise happens on and off upon driving and when I start car and idle. Almost 2 months ago fuel...
if you have climate control the a/c comp. comes on
intermitently if the clutch is going bad thats a suspect also the idler pully bearing could be tired
or the ps pump could be binding.
one way to narrow the field is the next you shut it off
after driving a short time see if any of the is noticably
hotter than the others thats a place to start.
hope this helps good luck
Jan 15, 2010 | 1997 Dodge Intrepid
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Longer warm up time accompanied by a loud grinding noise
There are few gears inside the copier that probably need to be replaced causing the grind and the copy quality to happen. It wasn't looked at by the engineer at the time because it happened after they left. They should come back in to fix it.
Aug 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Brother mfc 9429cn
we have two of these printers, they seem tohave a problem with the opc belt drifting to one side, insist they swap it before its out a warranty, the next problem you will have is the fuser unit which will start to make a noise and jam prints, again this has happened with both my printers, they are both destined for the scrap heap at 18 months old as brother want nearly as much for the fuser as they do for the printer
Aug 20, 2008 | Brother MFC-9420CN All-In-One Laser...
NOISE
My machine had the same problem. A service tech looked at my machine and pulled out the OPC Belt Drum Unit. The drum unit had a few issues: 1) jagged rips in it, something caused by running papers through that had staples or paperclips in them. So when the drum turns, it scrapes other parts and the machine sounds like its going to drop all its nuts and bolts--at least mine did!)! and 2) the spindles from the OPC unit has come loosened and fell off. The spindles and plastic cogs were found way at the bottom of the OPC Drum slot. This too was thought to have added to the rips in the drum.
I replaced the drum ($399 was the cheapest I could find) and the problem went away.
An expensive repair but for me it worked...
Aug 05, 2008 | Ricoh Aficio SP-C210SF Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
826 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
