Question about Yamaha HTR-6130 Receiver
How do i get sound thru hdmi - Yamaha HTR-6130 Receiver
    Brigadier General:
  • 8,546 Answers
Connect it. Is there more you could be telling us?
Posted on May 12, 2010
HDMI out showing on rceiver
as best to my knowledge sound doesn't travel thru the hdmi cable (only video), but travels thru another cable that is connected to the back of the receiver , some of the receivers even use a optical fiber (tos) for the sound to travel in
Dec 03, 2015 | Audio Players & Recorders
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
Jun 03, 2013 | Sanyo Dp55441 TV
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
No sound thru tv using hdmi cabl
my ps3 has no audio thru hdmi also, but its because its set thru audio settings to output only from my optical cable check your audio setting
Sep 02, 2010 | Sony Playstation 3 (PS3) Console
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Dish network VIP722 DVR - cant get sound to pass thru TV
HDMI is digital sound. I don't know why it's not passing through. You could run a set of audio cables to the surround sound. The not a noticable difference in my opinion.
Mar 15, 2009 | Televison & Video
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
Hdmi no sound
Check your Sound Settings on the CrossMediaBar and make sure that you have the audio set to come thru the HDMI and not the component. That should do the job.
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Yamaha HTR-6130 Receiver Logo
110 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
