Question about Brother SE-270D Computerized Sewing Machine
I was sewing and all of a sudden it started to slow down and stopped. Have tried to sew again and sounds like it is jammed. I have taken machine apart and there is nothing visible that can be in the way. The needle did not break and there was no jam when it stopped. The knob will move some in both directions but will not make a complete turn.
  • 240 Answers
Please try removing the bobbin case and then move the wheel. It is very likely that the bobbin case came out of place and causing the machine to lock up.
Thanks,
Pat
Posted on May 12, 2010
2 Suggested Answers
SOURCE: the needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Posted on Jul 29, 2010
How can I fix a jammed, squeaky hand wheel?
This sounds like a bushing in your serger or the upper looper shaft heats up with use. This the swells the metal and seizes the machine. This is always hard to fix right because there are many points on the serger that need regular lube and can heat up. it is an eliminate 1 joint at a time and try agein
May 28, 2014 | Husqvarna Huskylock Computerized 910
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Motor runs, but machine won't sew. When I was sewing, all of a sudden, the machine slowed down more and more than quit. The motor still "whirred", but the machine would not sew. It sounded like a jam...
If the machine has sat for a long time it probably needs servicing. oil has a tendacy to break down and turn to varnish gluing everything together. a simple service should fix it, you can ship the machine to me and i can fix this problem. keithat11@aol.com
Aug 06, 2009 | Sewing Machines
My singer touch & sew suddenly didn't stop
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
Apr 28, 2009 | Singer 1120 Mechanical Sewing Machine
Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Feb 02, 2009 | Sewing Machines
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Brother SE-270D Computerized Sewing Machine Logo
146 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
