Computers mother board gives a long beep without ram inserted, then makes no noise once ram is inserted and nothing else installed. is this normal?
  • 74 Answers
If it has nothing else at all installed in it, then yes it is. The long beep tells you something is not right in boot sequences.
Posted on Mar 28, 2008
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Jan 26, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
1st question== my friend gave me a p4vmm2 v8.1 mobo but when i turned it on it making a long one beep sound simultaneously inside ! there is no ram inserted! Is that the problem?????????? 2nd...
that's a functional motherboard you got there. The beep that you hear is an error beep for not reading a ram. Yes, you will insert a ram that is compatible with your motherboard. No you can't use that without a video card. If you've got a spare video card put it on your motherboard
Aug 02, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
I HAVE INTEL DG31GL MOTBOARD I HAVE ONE PROBLEAM IN MOTBOARD IS NO DIPLAY ONE SINGNAL LIGHT IS GLOW
Hell Krishna,
The display problem is common in all the Intel DG31GL motherboard. Please switch off the computer first. Then remove the Li-ion cell/ battery of the mother board. Replace it with new Li-ion cell/ battery.Also remove the ram of the motherboard. Insert the cell/battery in the motherboard and switch on the computer without installing the ram. After 2 to 3 beeps switch off the computer and install the ram and then switch on the computer. The display will come again.
Jun 01, 2011 | Intel Motherboard
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
No display on mother boards
Are these computers all emachines? this board is normally used in the emachine range of computers and have a problem with the architecture Call me ? chris http://www.motherboardsrus.net 07926-106150
Jun 05, 2009 | Intel D845GVSR Motherboard
No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Feb 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
