Question about Polaris Pb4 - 60 Booster Pump
Do you have an exploded view showing how the ceramic and spring go on?
  • 20 Answers
Most pumps actually have the spring and carbon side of the seal attaching to the impeller... with the ceramic piece and rubber insert going into the seal plate.... dont forget if you have a whisperflo that you have a reverse threaded machined screw to remove in the impeller before any of this can be started
Posted on May 24, 2010
  • 990 Answers
The ceramic goes rubber side first into the back of the impeller. The spring piece gets pressed into the seal plate. I will usually just use a 1" PVC coulping and lightly tap into the seal plate with that. But sorry I don't have any pictures to send but you should get instructions with the new seal in the box. You should end up with ceramic against graphite when your done.
Posted on May 13, 2010
  • Kieran Ruppert May 24, 2010
    You should not confuse the Wisperflo pump with the polaris PB4 the man is asking about. The ceremac goes into the impeller and the graphite goes in the seal plate. It's that way on most pumps that take a 1000 seal.
Replacingspringinpoulanhandel
I'd suggest going to Jacks Small Engines on line. Look up your saw by model and or serial number. Find a parts breakdown in their files...its all free.... and look at the exploded view of your particular saw. There you will find the correct orientation of the spring and related parts that have to be aligned to re install. There ARE NO directions, just an exploded view. It will help.
Sep 21, 2014 | Poulan Piston Ring Fits 2300av 2300cva...
Choke carburetor spring assembly
many Craftsman mowers use Briggs and Stratton engines. Go to the B & S site and look up an exploded view of the engine. It should show where the springs go. Follow the diagram and please be very careful.
May 07, 2014 | Craftsman Garden
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
SHOW SPRINGS SCHEMATIC ON PREASURE SWITCH
Are you talking about a wiring diagram or an exploded view of that switch?
Jun 08, 2013 | Craftsman Air Tools & Compressors
The soap dispense cap (shaft) broke and I need to replace it. The dishwasher model number is GSD4330y73WW. When I took back panel off I see it is operated by a cam with a spring. However I do not know...
Many sites such as partsselct.com have exploded views which show how it all goes together...parts often have instructions with them also...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 04, 2011 | GE Dishwashers
Clutch just quit engaging, found small spring in the case/cover, need an exploded view of clutch assembly and a photo of new clutch plates.
For an exploded view of your clutch, go to www.bikebandit.com . The only spring that I can think of in the area is a small srping in the release mechanism but I can't figure how it got inside the case. As for your clutch plates, as long as they've got the oil grooves in them, they're fine. Although they don't look like much, they'll work.
Good Luck
Steve
Dec 25, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
1990 rm 250 repair manual. how to set low idle, and kick start lever and spring doesn't spring back up
The site listed below has exploded view diagrams of all sections of your bike with parts named. This will show location of your idle screw. The diagrams will also show how the kicklever goes together.
Cheers.
http://www.cmsnl.com/suzuki-rm250-1990-l_model14078/partslist/
Nov 06, 2010 | Suzuki RM-Z 250 Motorcycles
Dryer belt replacement
Here's a URL to a website showing an exploded view of the parts in your washer, and I noticed that one of those drawings shows the proper belt path for installation: --> http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0 Hope this helps! :)
Aug 02, 2007 | Crosley CDE6000 Electric Dryer
Polaris Pb4 - 60 Booster Pump Logo
258 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
