Question about Gateway 24" Widescreen Flat Panel TFT LCD HD Monitor
My FPD2485W MONITOR WENT BLACK
I was the screen and it just went black. I suspect it is just the capacitors inside blew. Has anyone had any luck repairing these
  • 3 Answers
Unplug everything from the monitor, than push the on button for 30 seconds. Plug everything back in, and that should power it back up. I had the same problem, and apparently there was a build up of static electricity in my screen. Fixed it right away.
Posted on Jun 21, 2010
  • 11,361 Answers
You can open it up and inspect the caps in the power supply first, if they look OK then you need to check to see if you do have 24vdc feeding the backlight inverter board, it can be that you have blown fuse on the inverter board.
You can read more about other people that try to repair it, http://www.badcaps.net/forum/showthread.php?p=45010
http://s807.photobucket.com/home/budm/allalbums
http://www.topix.com/forum/tech/TNTK13PFRQURRRJJC
Posted on May 12, 2010
Blew a capacitor on my JKEXER Vigor 6090 treadmill, need to know what size capacitor fits onto circuit board marked CNR1...
Hi there, well, let's back up a bit. The Capacitor that blew may have been in parallel with one or more and other caps could be suspected as bad or close to it. You can contact jatinah electronics for repair help, as control boards have seriously dangerous voltages and currents, live parts, and "Hot" grounds on motor power rails. Good luck
Feb 06, 2015 | Exercise & Fitness
Why does my samsung plasma 550 have no picture?
It sounds like a capacitor blew in one of the internal circuit boards. A capacitor makes the pop you described, and techs actually refere to them as "being popped".
Sep 05, 2014 | Samsung Televison & Video
What electrical part is connected to the capacitor inside a grundfos up15-42f circulating pump?
Hugh sadly as a retired Heating engineer I think you may be easier to buy a new heating pump as these things are not on the market to purchase.
Aug 02, 2014 | Grundfos Pumps Grundfos UP15-42F 1/25 HP...
Loud pop, sounded like a gun shot, screen went black, sound wasn't affected P42 HDTV A 10
This sounds like the tripler for the lcd display, or a capacitor in the power supply board blew. You can replace them yourself if you can indentify the bad part(s), but this will require some disassembly to get at them, of course.
My suggestion would be to get a mobile repairman out to fix it. Many towns have them these days, and they will come to your place to fix it, and they're reasonable.
You can google "Tripler replacement" and get some information on it, if you elect to try to repair it yourself.
Good luck, and hope this helps.
May 30, 2011 | Vizio P42HD Television
TheTV made a loud pop and the screen went black. Now I have blinking red lights.
You probably blew up a capacitor. Unplug the television and open up the back. Check for bad caps. You'll probably find a puffy one. Check the fuses to see if they're blown. If you find a blown fuse, start looking for bad diodes or a bad transistor. If you don't know what I'm talking about then don't ruin a good television set by poking your nose inside and blowing something else up or end up zapping yourself when you touch the wrong thing. Take it to a professional and get it fixed. Good luck.
Apr 24, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
When i turn on the screen the logo flashes for about 2 seconds then the screen goes black.
This problems is a long board call the LCD inverter board is dead.This long LCD inverter board it help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 01, 2010 | Gateway FPD2485W Television
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
My monitor FPD2485W is unresponsive. It won't start.
This monitor is released in 2007, more likely to have failed components by now.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 04, 2010 | Computers & Internet
Black screen
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | ViewSonic VX910 19" LCD Monitor
Tv popped and went out
Pops' are never a good thing to hear especially from rear screen sets. Could be that one of the three CRT's went/impolded. Could also be a Capacitor that blew also. Might be best to call a RV repair shop that works on Akai's - I think Magnavox builds Akai's but that's a guess.
Blessings,
A/V Media Guy
Nov 20, 2009 | Akai PT4298HD Rear Projection Television
Gateway 24" Widescreen Flat Panel TFT LCD HD Monitor Logo
599 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
