Question about GE Spacemaker JVM1640SJ Microwave Oven
I'm trying to remove my ge spacemaker microwave from above the stove
    President:
  • 1,033 Answers
Inside the cabinet above your microwave, usually you will have 2-3 lag bolts screwed through the bottom of cabinet into the microwave top. After these are removed, you will have to pick the bottom of the microwave up and tilt outward and up. The back of the microwave is attached to a bracket on the wall and this is why it has to be tilted and pushed up off the bracket. Get an extra hand for this, it's not heavy just awkward. When installing a new one the old bracket will work with the new one.
Posted on May 11, 2010
I need to remove a spacemaker microwave from over the stove. I have removed all the screws that I can see and it's still rock solid. Suggestions?
As I recall the only 2 or 3 long screws that you need to remove are in the cabinet directly above the microwave. You will also, of course need to unplug the microwave above it as well. Is should now hinge down, as the back edge hooks onto a mounting plate on back wall.
Jun 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need GE Spacemaker parts..
SEE http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
75 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
