Question about Kenmore Oasis HE 27082 Top Load Washer
Error code oL - Kenmore Oasis HE 27082 Top Load Washer
  • bandswilson May 11, 2010
    MY OASIS ELITE WASHER IS DISPLAYING THE CODE Ol
    Top Expert:
  • Kenmore Master
  • 76,630 Answers
OL ERROR
Possible the rotor position sensor is malfunctioning. You can perform the test #3 on page 9 in the tech sheets but I would recommend to call an authorized tech because this washer is very complicated.
BELOW IS LINK TO SERVICE MANUAL. TEST #3 ON PAGE NINE IS TEST FOR THIS ERROR CODE. THIS REQUIRES HANDS ON DIAGNOSIS, SO ANY SUGGESTION I MAKE WILL BE BASED ON WHAT U COME UP WITH IN THE TESTING.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
Posted on May 11, 2010
  • yadayada
    yadayada May 12, 2010
    also make sure u don't have the machine overloaded
  • 8,197 Answers
The Kenmore Oasis is the same machine as the Whirlpool Cabrio, FYI> The oL code means the motor control board is struggling to power the motor up. Usually this means a new motor control. If it were a problem with the tub floating up, the unit would spin instead of nutate. I am attaching the Tech Sheet below so you can run some of the diagnostic codes that your inept repairman did not:
Tech Sheet for this washer
You will find the entire Cabrio washer manual in the Whirlpool section of this forum should you decide to see how the machine is put together, etc.
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
Ol code cabrio
"oL" error code, even when unloaded - Fixitnow.com
fixitnow.com/.../whirlpoolkenmore-cabrio-and-maytag-bravo-washers-th...
Sep 18, 2010 - The "oL" error code in the Cabrio and Bravo washers means the ... is almost always caused by using non-HE detergent in this washer- see this ...
Aug 17, 2015 | Washing Machines
Cabrio washer error code OL after about 10 mins.
The ol error can be caused by many problems, first let's address the over filling of the water, there is a plastic tube that runs from your control to the outer tub. This tube provides the pressure to the sensor in the control board to control the water level in the tub of the washer. If this line has a pin hole or is clogged, this could effect the water level. If your tube is ok then the control board is bad.
the ol error could be any of the following:
cloths under the tub,
bad bearings
basket hub
stater motor
rps sensor
control board
Mar 27, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Fuel system default code ol
Have the cylinder one misfire repaired and other codes will likely disappear.
Mar 01, 2013 | Toyota Camry Cars & Trucks
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code ol
Hi
Error OL means overload. oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5-10 minutes and check. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When washer spin the machine stop mark the code ol
Sorry I missed the error code oL
oL Machine Paused-Load Wedging….I think that may mean something like the tumblers are jammed up but that’s a guess. I have never seen that error code before. If no one on the forum can help I will give it a try. I need to do some digging in. If I hit a dead end for this error code I will ask on another forum if any Maytag repair folks have knowledge of this error code and it’s cause. We could do some basic troubleshooting if you want to try. If you recycle power on the machine will the machine run a normal cycle?
If you want to dig in and troubleshoot the issue I will try to help. See my last post of how to get into Service Mode. I would suggest reading the Diag codes and see what the machine has logged with past error codes.
Here are links for the Service Manual and parts look up. FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Waiting to hear back from you….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
310 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
