Question about Gateway GT5678 Desktop PC
My Gateway GT5678 does not burn CD's... when I insert a CD-R or anything other than a DVD, it does not recognize it.
  • 2,229 Answers
My opinion would be that your CD/DVD drive has gone bad and must be replaced. This is not uncommon.
Posted on May 11, 2010
Does not recognize disk
Either:
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
Wont recognize burned disk
Is the burned disk recognized in some other computer?
Is any "official" (purchased music CD, or purchased DVD video, or purchased Microsoft software) disk recognized when inserted into the device?
If you burn a disk on your computer, can your computer then read that burned disk?
May 29, 2010 | Toshiba PA3761U-1DV2 DVD-RAM Burner
DVD Writer not recognizing DVD
the drive is not recognizing any dvd. this happens when you insert dvd into cd drive. if this happens with dvd drive its factory malfunction probably so if you can-replace it
Oct 02, 2009 | LG GSA-H55N DVD-RAM Burner
No music on burned discs
You need to try a commercial cd of any kind. You just want to see if it reads the cd. Then you want to try a dvd and see if it reads that. If it reads the cd but has trouble with the dvd then the heads are out of alignment. It might still write a cd but not be able to write a dvd as that require more accuracy and it doesn't have it anymore.
You may still be able to use the drive but you will have to replace it. The symptoms you describe are typical of the driver going out of alignment so I would say you are heading for replacement sooner or later.
These are not cost effective to repair anymore so all you can do is replace them. Unless you can get it replaced under warranty you can replace it for under $50 at any local computer store.
Jul 10, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
My dvd-cd drive wont read DVD's and wont burn music CD's. sometimes it wont even recognize that there is a disk in the drive it says please insert disk. i have a gateway MT3705 laptop.
There is a slight possibility that your drivers could be corrupt or may not be there at all. You can check that by going to the device manager and reloading the drivers. You can also try doing a system restore back to the time when your drive was working. Most likely, I would think that your cd drive would need to be replaced.
Jun 17, 2009 | Gateway MT3705 Notebook
DVD/CD drive burns, spins, won't read DVDs or CDs
CD and DVD use different lasers. You appear to have a bad or out of adjustment laser. Replace the drive.
Mar 01, 2017 | Sony Computers & Internet
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Gateway laptop pc wont recognize blank discs in drive E:
Are you sure E: is the cd/dvd burner?
Can you put a cd with music or a dvd movie in there and get it to play it?
Mar 19, 2008 | Gateway 7330GZ Notebook
Disc drive will not recognize blank discs.
let's make sure that's a DVD RW disk shall we? check the front and make sure it says DVD RW..if it's DVD R, then it can't write.
Mar 17, 2008 | Gateway 7330GZ Notebook
Gateway GT5678 Desktop PC Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
