Question about JVC AM FM CD DET FACE CAR STEREO
I have no sound and tried all trouble shooting with reset button and volume controls. Is the radio shot JVC KD-S790
  • Damon Schneider May 13, 2010
    Can the out puts be replaced or fixed and is it worth it versus a new radio?
    Any ideal of what one could expect as far as cost to be fixed?
    President:
  • 2,317 Answers
If you try a known good speaker on each of the four outputs of the stereo and you get nothing from any of the outputs, the outputs in the stereo is bad.
Posted on May 12, 2010
  • James Milzheimer
    James Milzheimer May 14, 2010
    I think it would cost more to fix the stereo than to replace it.
How to set time on JVC KD-R200 car radio.
Try this.
Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
How do I reset the time on my JVC KD-R200 CD RECEIVER/ WMA MP3 PLAYER?
I am not sure about the reset. You can change time. Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Set the clock on a jvc KD s670 car stereo radio?
Press and hold SEL until menu appears
Using the (SSM) / scan (FWD/REV) button , select Clock H
Using the volume knob/button, set the value
Using the scan (FWD/REV) button , select Clock M
Press SEL to save and exit
Jun 15, 2010 | JVC KD-S670 CD Player
Unit is not resetting
try disconnecting your battery and wait for a couple of minutes, then reconnect the battery. hopefully this helps
Feb 23, 2010 | JVC KD-S890 CD Player
Set the clock
how do i change the time on a jvc kd-s790 stereo?
Nov 11, 2009 | Car Audio & Video
Jvc kd-s590, installing in other car and only the att (red) light comes on no display or sound. tried resetting, fuse is good. that's it.
sounds like only the constant(yellow) wire has power. you need to make sure that the switched wire(red) has power as well. good way to trouble shoot, is to hook the red to the yellow to see if it powers up then, if so you know the radio is ok, you just need to find a better power source for the red wire. hope this helps.
Aug 18, 2009 | JVC KD-S570 CD Player
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
Set clock on radio
Hello atesha23,
Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
(1). Enter the PSM mode by pressing and holding the
SEL button until the display changes.
(2). Use the rocker switch left/right until "CLOCK
H" is displayed.
(3) Set the clock hours by turning the volume
control up/down.
(4) Press the rocker switch again until "CLOCK M"
is displayed.
(5) Set the clock minutes by turning the volume
control up/down.
(6) Press the SEL button to finish and EXIT.
Hope this helps.
Mar 31, 2009 | JVC KD-G140 Car CD Player
My JVC kd-s570 its not working what can i do.?
hold the SEL (select) button and top left power buton together for 2 sec. that will reset it.
Nov 08, 2006 | JVC KD-S570 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
311 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
