Question about Nikon COOLPIX S10 Digital Camera
Camera lens error when I power up camera - Nikon COOLPIX S10 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 12, 2010
I keep getting error 99 message
Error 99 is common error on Canon cameras. Make sure the battery is freshly charged. Take the battery out, the compact flash card out, and the attached lens off of the camera. Leave the camera set for a while for the capacitors to bleed off. Around a half hour would be good. Next re-insert the battery and push the shutter button as if you were taking a picture. If you get an Error 99 then, you can't fix the trouble and Canon will have to do it. If you do not get an error 99, power the camera off, insert the compact flash card, power the camera back on and press the shutter button again. If you get an Error 99, the trouble is in the compact flash card or its connector. Try a different card. If you do not get an Error 99, power the camera off, a lens on it, power the camera back up, then press the shutter button once again. If you do not see an Error 99, the problem is no longer in the camera. If you do see an Error 99, power the camera off and remove the lens. The problem is probably in the contacts on the camera or the lens. Clean the contacts by holding the camera carefully with the lens opening down so it will not allow dirt to get inside the camera. Take a cotton swab dipped in alcohol and clean the gold metal contacts well, Dry the contacts with a tissue. Next hold the lens with the contacts down and repeat the process on the contacts on the lens. Be very cautious not to allow lint, dust, or alcohol to get into the camera body or into the lens. Some people use a pencil eraser to clean the contacts but you have be very careful not to let particles enter the camera or lens. This should clear your trouble, if the camera passed the first step of troubleshooting.
Nov 02, 2013 | Canon EOS 40D Digital Camera
1 MSG WHEN POWER IS TURNED ON 2 LENS ERROR -
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 09, 2011 | Canon PowerShot A710 IS Digital Camera
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Lens error, restart camera
Jun 28, 2009 | Canon Cameras
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Apr 16, 2009 | Canon PowerShot SD600 Digital Camera
Camera will not stay powered up and lens won't come out
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 15, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Camera lens will not open
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Nikon COOLPIX S10 Digital Camera Logo
93 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
