Question about Asko 24 in. 1885 Built-in Dishwasher
How to change the interior light after it fails in an Asko 1885 dishwasher
  • Asko Master
  • 12,061 Answers
Http://fixitnow.com/
www.askousa.com/
http://www.repairclinic.com/Appliance-Parts?s=t-%20Asko%2024%20in.%201885%20bulb-%3d%3d
Ok the above links should help. the link directly above is for your bulb.
Posted on May 12, 2010
I need to replace the plastic panel on the outside/top( which is the width of the dishwasher and approximately 5-6 inches high) of the dishwasher door on an Asko 1885 model. I ordered the piece from Asko...
Hello, welcome to FixYa.
Having done work for Asko for many years I can tell you you're not going to find a technical service manual on-line for these machines because Asko does not release them.
I can, however offer you a complete illustration of all the machines components including the control panel, thus you should be able to interpret how the panel comes apart.
To address the issue of the entire outer panel coming off, it is easier that way in my opinion, but whether it is necessary I think is up for debate...I usually remove it when I service them.
The sections you are speaking of are indeed "snapped" into place with the exception of the latch assembly and relatively easy to remove from the back. Here is an example of the illustrations I can provide (I can also guide you thrrough the process since I have changed a number of them first hand)
Let me know if this may be of any use to you and I'll send it to you...though you need to post an email address with your reply if so. I'll watch for your reply.
Regards,
Macmarkus :)
Aug 31, 2011 | Asko Dishwashers
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Circ pump runs, but does not pump
Oppen the centre orifice , remove cover , remove impeller , clean debri and change impeler with new one, Vitally
May 13, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Asko 1885-1895 heater element replacement
Remover the lower front panel, and from there you should reach the element nut. Good luck
Feb 14, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 24 in. 1885 Built-in Dishwasher Logo
311 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
