Question about Acer X193W LCD Monitor
Monitor screen won't stay up. Monitor is connected to Gateway PC which is running Windows 2000.
  • Acer Master
  • 12,061 Answers
Http://www.retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
You have to prove if it's the monitor or the PC, you must swap out, for Known Good, units. Check your monitor on another PC, try another Monitor on your PC. This will soon zero you in on the faulty item, be it, the monitor, or the Video card/PC
Posted on May 12, 2010
Gateway desktop screen is black
Swap the cables between the PC and the monitor. Does the fault stay with the monitor or switch to the PC? If it switches, your power lead is dead (possibly a blown fuse). If it stays, your monitor is probably dead.
Aug 29, 2014 | Gateway Computers & Internet
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
My monitor was fine for over a year, but now when I turn on the monitor, the screen goes black after 1-2 seconds, but the green power light stays on. I can turn it off and on again over and over like this,...
check the cable connected to the monitor
run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
May 23, 2017 | Mag Innovision Computers & Internet
I have a gateway gt4015e. When I turn the power on the screen does nothing just stays black. This is a windows media center 2005 machine. Please help
Make sure the computer and the monitor both have power going to them and that they are both on.
Make sure that the cable from the computer to the monitor is connected firmly. You have to determine if you are using a video card or on board video (video built into the motherboard). If you have two ports to plug into on the back of the pc make sure you are plugged into the right one. Try to use the monitor on another computer or a different monitor on that computer to see if you can isolate it to one or the other.Could be a bad cable,video card,or monitor. You should try to test the devices to narrow it down.
Jan 10, 2011 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
The power went off in my house for 15 minutes. When it came back on everything worked except the Gateway PC with Windows XP and the monitor which was connected to a surge suppressor. The PC won;t come on...
If the monitor is out as well then the surge suppressor did its job and took the hit, basically rendering it useless now, try plugging in the system and monitor directly to the wall, it they work then you need to replace the surge suppressor.
Sep 19, 2009 | Gateway GT5220 PC Desktop
My MT3422 gateway will not boot up.
Sounds like an internal graphics problem then motherboard fault.
http://www.notebookforums.com/post2949935.html
Aug 03, 2009 | Gateway MT3422 RTL Notebook
Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Nov 06, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway monitor will not work on non gateway PC.
Joe,
It's could be the backlight inverter are busted...try plugged to another PC. If it still the same problems... Replaced a new backlight inverter or repaired it.
Oct 14, 2008 | Computers & Internet
TFT Monitor Dislay fault
this is a hardware issue with the monitor. I hope you kept a receipt with contact information for the seller.
Make sure the cable doesn't have any bent pins too on both ends.
Jun 15, 2008 | Gateway FPD2275W LCD Monitor
Acer X193W LCD Monitor Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
