Question about PreSonus FIREPOD (673454000539) Audio Input
My computer will not recognize my firepod - PreSonus FIREPOD (673454000539) Audio Input
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I am using a presonus
Have you been able to successfully do this in the past? What software are you using to try to record with? Does it seem to recognize the guitar in the software, just will not react, or does it not appear to see it at all?
Thanks, let me know and I can help!
Tim
Posted on Sep 16, 2010
Presonus firepod pinouts
Try shooting an inquiry directly to PerSonus.
Feb 20, 2014 | PreSonus FP10 FireWire Recording Interface...
Loud hum / all tracks crosstalk each other
If the noise does not depends on cables and connections, or interference from devices, then It looks like there is some blown component inside.
Sep 29, 2008 | PreSonus FIREPOD (673454000539) Audio...
I am using a presonus firepod into Logic pro 8 and it wont recognize the audio I am trying to record into it. I recognizes the Firepod which is chosen for input and output (output works fine). However when...
Tim
Sep 16, 2010 | PreSonus FIREPOD (673454000539) Audio...
No power! The same thing has happened several times in the past and after opening it up to check the fuse and putting it back together it miraculously worked again. This time,,, no luck. Any suggestions?
Actually, the problem is the little white connector next to the fuse. Mine dead stopped turning on one day and I found the solution. You will need a appropriate sized phillips screwdriver, a head lamp or LED keychain that you can aim from your mouth, a slim flat head screwdriver, and some skinny needle nosed pliers.
-- unplug it.
-- Unscrew/remove the right side panel, on the side of the AC connector (I don't advise opening the entire box as it was a bit hard for me to get back together)
-- fire up your light source, you'll need it!
-- *looking at the now open unit form the open side* you will see the green mainboard horizontally across the bottom.
-- *key in on the near right corner next to the small clear tube fuse*
-- the part that is having problems is the wire lead that has a small white vertical plastic connector, (near right corner next to the fuse) (it will probably have a white "tab" coming from the connector that is slightly out of place)
-- take the needle nose pliers, gently grasping the plastic connector on the wire side, and disconnect the wires from the mainboard connector. (may help to use the slim flat head driver to help dislodge this).
-- once it is disconnected, use the slim phillips to realign that white "connector tab" and slowly (making sure to not bend the pins) re-connect that wire piece with the mainboard connector.
Plug the power in and try flipping it on. Hopefully this fixes it for you. I have had to do this about every 6 months over this last year, but its cheaper than buying a new card!
May 06, 2010 | PreSonus FIREPOD (673454000539) Audio...
My Win7 does not recognize my 2005 Firepod, when i get to the point that it tells me to connect it and turn it on, it does not continue installation, it just keeps repeating for me to plug it in and turn...
Win 7 is probably incompatible with the Firepod. Others find the same thing and unless the Firepod manufacturer writes new drivers, it will not work with Win 7.
Probably the best course of action is to go back to XP or the previous OS you have used with it.
NEVER switch operating systems without checking that hardware and software is compatible with the new OS.
Microsoft is notorious for incompatibility of new OS versions such as Vista and now Win 7.
Jan 12, 2010 | PreSonus FIREPOD (673454000539) Audio...
Not being recognized
Same exact thing happened to mine, sent in for repair, cost me $30 to ship it to them plus they $85 to repair it, and it still doesn't work.
Presonus hasn't done anything about it. Put your $ towards something new and MADE IN THE USA.
May 07, 2009 | PreSonus FIREPOD (673454000539) Audio...
Cubase se 3 problem
try selecting each imput as mono instead of stereo,and then back to stereo,after a reeboot this worked for me andy hope this helps
Jun 22, 2008 | Steinberg Cubase SE
Not syncing
Could be a bad cable, bad firewire card in computer, or the unit is damaged.  Might want to connect the unit to someone else's computer with a new Firewire cable.  If this doesn't work, chances are that the unit is defective.  I have the same problem right now and I'm having to send the unit back to Presonus.  They charge $85 for parts labor and the return shipping.  The replace the entire board, so it's like getting a new unit.  Hope that helps.
Jackie
Oct 17, 2006 | PreSonus FIREPOD (673454000539) Audio...
Open Questions:
See all PreSonus FIREPOD (673454000539) Audio Input Questions
PreSonus FIREPOD (673454000539) Audio Input Logo
104 people viewed this question
Top PreSonus Televison & Video Experts
Electro Med Services...
Are you a PreSonus Televison and Video Expert? Answer questions, earn points and help others
