Car amplifers,,,,kicker amp's RCA jacks!
I have 2 kicker amplifers 1-of them is a zx1000.1 mono amp and the other 1 is a zx650.4, 4-channel i have everything hook up axecp the RCA jacks between both amp's do you know ware they go, example,input to output or the other way HELP buzzman.
    Novelist:
  • 100 Answers
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Posted on Mar 29, 2008
I have 2 kicker cvr15 4 ohm duel voice coil speakers how do i wire them to a kicker zx1000 amp??????????
The ZX1000 is a two ohm stable amplifier, so this means that you have to connect your two voice coils in series to give you around 8 ohms impedance per speaker, then connect your two speakers in parallel to give you 4 ohms impedance on the single mono channel on the amplifier. I recommend you connect it up in the following manner:
Apr 06, 2011 | Kicker Car Audio & Video
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
2 channel amp with 2 Kicker Cvrs 15"
Assuming the amplifier is 2 ohm mono stable... the amplifier is bridgeable... and the subwoofers are Single 4 Ohm Voicecoils, You would wire them as follows....
Both + on Both subs to the + bridged terminal on the amplifier.
Both - on Both subs to the - bridged terminal on the amplifier.
This will net a 2 ohm mono load for your amplifier.
If you have something different - let me know... and I will give you the proper wiring for what you have.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Kicker CVR12 Car Subwoofer
Kicker ZX1000 Open ground issue
you probably have a bad ground to the rca's .
Apr 16, 2009 | Kicker ZX10001 Car Audio Amplifier
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
How to get the best out of this amp
"google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Kicker zx850.2 and two kicker s10l72
http://kicker.com/dvc_wiring , check this out. for that set up i would recommend either getting a mono amplifier or dual 4 ohm subs. hope that helps.
Sep 24, 2007 | Kicker ZX850.2 2-Channel Amp - 590W ZX...
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
193 people viewed this question
 Grubhead
Grubhead
