I have a Mitsubishi HDMI Projection TV hooked up with a Seven Year Old JVC DVD player that plays all DVD's other then those released within the last several months. Netflix/Redhat tells me the DVD Player does not DEcode the newer disks. I purchased two brand new dvd players one a Magnavox, and a Sony Blue Ray. I hooked up Component Cables and Optical Audio. I then changed the Input on the TV to Comp. 1 and the TV does not Pick up on the DVD Player at all. I tried RCA,S-Video and still nothing. I returned both Players. Can anyone advise what the problem is. The real kicker is the TV recognizes the Older JVC DVD player and will play all my older DVD's and it will not even recognize any other DVD Player including a Sharp DVD Player that is Brand new from 2003 still in original box. I hadn't used it since then because I was using the JVC Progressive Scan. So it is not that my TV is incompatable with newer DVD Players only.
  • 6,993 Answers
there is a fault somewhere. You need to take it to a repairman to fix the problem for you,
Take care.
Posted on May 28, 2010
  • Walesarumi
    Walesarumi May 28, 2010
    The fault is obviously from your TV. Its either the TV is not compatible with newer DVD's or the TV is having a fault.
    Maybe you should continue using your Old DVD player, or buy a more recent TV that has the ability to work with newer DVD players.
    Or call a repair man to help you check for any possible cause of the problem.
    I don't think this has to do with any settings, or adjustments.
    I hope you understand my explanations.
    Good luck.
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
Jan 02, 2016 | Mitsubishi Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
Bought new sony bravio blue ray dvd player hooked to hdmi port changed inout to digital one then tried changing port and trying in digital 2. same symptom on both sound perfect but no picture of any kind....
There are three only three possibility's here, one there is a problem with the HDMI HOOK UP ON THE BACK OF THE TV, SECONDLY IT COULD BE THE DVD PLAYER IS NOT COMPATIBLE WITH THAT TV, AND LASTLY YOU MIGHT NEED TO HAVE THE TV SERVICED FOR SYSTEM ISSUES
Mar 06, 2011 | JVC HD-70G886 70" Rear Projection HDTV
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
